Old 10-11-2009   #21 (permalink)
zoro
GHOSTRIDER
zoro's Avatar
Send a message via Yahoo to zoro
Never mind,
"GHOSTRIDER" 1980 KZ1000ST-E2
zoro is offline   Reply With Quote
Old 10-11-2009   #22 (permalink)
RichLockyer
RichLockyer's Avatar
Originally Posted by wdhewson View Post
Keith1: I guess the best elaboration is to say that the 15 to 20 chemical additives in a typical engine oil have specific and sometimes conflicting effects. So if Rotella-T is primarily marketed as a HD Diesel engine oil, then its gasoline engine performance will be a secondary consideration. Also, cleanliness additives like deterrgents and dispersant are very necessay in sooty Deisels, but these additives make anti-wear agents like the ZnDDPs less effective.
Except that bikes do not produce the levels of soot that Diesels do, but they do shed clutch material.
But if Rotella is so bad, then how is it that it meets JASO-MA specifications... it is simply not rated JASO-MA because it's target market is HD truck service and it would be a waste for Shell to pay the licensing fee to have the JASO-MA label.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 2 Weeks Ago   #23 (permalink)
squawk
Finally Got Into First Gear
Just an update to let everyone know that I finally got the Oil Filter ring and washer and will be draining the oil yet again next week end...Yeah...can't wait!!!
squawk is online now   Reply With Quote
Old 2 Weeks Ago   #24 (permalink)
squawk
Well I can tell you this it runs a lot better with the spring and washer. I would suggest anyone who notices that there's is missing next time they change their oil invest in them and put them on.
Old 2 Weeks Ago   #25 (permalink)
Ed.B
Rotella-T is rated for motorcycles, and test results back it up in the real world.
Also it is considered to be the best oil to use for cam break-in in new engines with flat tappets (and breaking in new cams and flat tappets in old engines).
Rotella "T" JASO/MA Certified - Bob Is The Oil Guy
1998 Goldwing Rotella T 5w/40 4207 miles - Bob Is The Oil Guy
Ed.B is offline   Reply With Quote
Old 2 Weeks Ago   #26 (permalink)
sbc1320
sbc1320's Avatar
Default Shell Rotella
Shell Rotella is a great oil to use for flat tappet cam break-in because of its high zinc content. I used to do a lot of muscle car motors and wouldn't put a new cam in without. You are taking a gamble if you don't use it. Of course use the cam and lifter lubricant, bring new motor up to 1500-2000 rpm for about 20 minutes varying the throttle. Cams only get oil splash to the lobes. I figure would be the same for motorcycles also. Roller cams like my last motors(car) have no break-in problem(cam). You may or may not have this problem, but I personally wouldn't take the chance. I personally wouldn't pay the extra money for synthetic oils either regardless of a few horsepower gain. Just my two cents. I am a 50 year old mechanic and have been building engines for over 30 years. Haven't built any motorcycle engines other than doing the topends.
sbc1320 is offline   Reply With Quote
Old 1 Week Ago   #27 (permalink)
wdhewson
Turtle Wax Taster
wdhewson's Avatar
Guys. Good thread and thanks for the information. But a few questions remain. I'm out of date, but does I think JASO MA just looks at the friction properties of wet clutches, and with only one friction material. So limited testing and nothing to do with cams and tappets. If somebody has a connection with Shell Global solutions, ask them what engine is used to evaluate cam and tappet wear in the formal approval of Rotella T. Do we think that it is even a motorcycle engine, much less a Kwaker engine?
Sarnia, Ontario, Canada
1981 KZ550A2
2003 ZR7S
1980 KZ1000Police Wanted
wdhewson is offline   Reply With Quote
I was bored, so here's my experience with my first oil change. 98ninja98 Main Lobby 20 10-04-2009 10:56 AM
brute force problem with oil in air filter rincon45 Kawasaki ATV and Mule 1 12-20-2008 08:33 AM
Oil... Completely Off Topic... kawichic Off Topic 20 12-12-2008 08:57 AM
Bike Oil vs Car Oil... Brett The Mechanics Corner 55 08-05-2008 10:24 PM
men's rules for women - wouldn't let the wife see Freakinout Off Topic 48 02-26-2008 10:59 AM
