Old 10-08-2009   #1 (permalink)
squawk
Finally Got Into First Gear
Default Self-cancelling turn signals?
I just read that the turn signals on my 1980 KZ750 LTD has them mine don't. It also says that you can set them to manual, wonder if that's what the previous owner did of if they are broke. Can someone please tell me how to set it so that I can se if that's what he did?
squawk is online now   Reply With Quote
Old 10-08-2009   #2 (permalink)
Bill Frazier
Foil Inspector
Bill Frazier's Avatar
I don't have a KZ750, but my bike has self-canceling signals. The left grip has a horn button, a high/low beam switch, a turn signal switch, and a manual/auto switch. It's just that simple. If you don't have the extra switch, you don't have the feature. BTW, mine hasn't worked for years, even after tearing the switch all down and cleaning everything twice. It worked for a few weeks the first time I fixed it. It just didn't seem to be worth the effort to work on it anymore.
Bill Frazier
1982 KZ440LTD
Original owner
Bill Frazier is offline   Reply With Quote
Old 10-09-2009   #3 (permalink)
squawk
Thank you Bill apparently I do not have that option!
Old 10-09-2009   #4 (permalink)
StarGate
StarGate's Avatar
I have self canceling signals but there is no auto/manual switch on the hand controls.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 10-09-2009   #5 (permalink)
squawk
So can you turn your auto-canceling feature on and off?
Old 10-09-2009   #6 (permalink)
StarGate
StarGate's Avatar
If there is a way to disable it, I'm not aware of it. I've never seen any info in the owners manual about being able to do that.
One easy way to check if you have them would be to open the left side switch housing up and see if there is a small solenoid inside.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 10-09-2009   #7 (permalink)
squawk
Thanks for the information StartGate!!!
Old 10-10-2009   #8 (permalink)
kawah1c
Way Too Much Free Time
kawah1c's Avatar
Mine doesn't work either (Z1-R). I have the auto/manual switch. Word is that this feature self cancelled itself (as in broke) after a relatively short period of time. I got a nos one on the shelf, maybe I'll put it on some year
Z1-R, H2, W650, H1C, F-11 ,G4TR ,KV75-A7 ,MT1,
KV80R-A, XL70-K1
kawah1c is offline   Reply With Quote
Old 10-10-2009   #9 (permalink)
AtLarge
AtLarge's Avatar
I don't have an on/off switch. Just this under the right side cover.
And ya, mine self cancelled itself too.
1983 KZ750-K1
AtLarge is offline   Reply With Quote
Old 10-10-2009   #10 (permalink)
StarGate
StarGate's Avatar
Mine stopped working shortly after buying the bike. Took it in to the dealer because it was still covered by warranty. They replaced the odometer thinking that was the cause then replaced the control unit (bottom of battery case on mine) and fixed it. It quit again a few years later. When I stripped the bike to powdercoat the frame I found that the harness from the control unit had been rubbing on the battery case and had rubbed 2 wires completely through and a third was bare and grounding out to the case. I spliced the wires back but it still doesn't work.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
2 turn signals blink too fast keithert Kawasaki Cruisers 5 08-07-2008 02:38 PM
98 zx9r turn signals flash rapdly truckermatt Kawasaki Streetbikes/Sportbikes 1 07-13-2008 11:14 AM
Turn signals zeiss150 Vintage Motorcyle Info 4 03-20-2008 05:13 PM
Flush mount/Integrated Turn Signals NinjaJeeper Kawasaki Streetbikes/Sportbikes 17 09-20-2006 01:21 PM
Replacing your stock front turn signals - Mean Streak SleekStreak Kawasaki Cruisers 10 08-18-2005 09:57 PM
