Could be a number of things but I'd probably start with testing the coils, new plugs and wires and do the coil power rewire mod.
P.S. When is the last time the valves were checked/adjusted and the carbs synced? |
Needs A Real Job
Have you checked the input voltage to the ignition coils? Do this:
1. Fully charge the battery. 2. Remove the gas tank. 3. With the key turned on and the run/stop switch to run, get a mutimeter(analog or digital) and check the primary side(small wires) of the coils. 4. They should read battery voltage or a little less, if it's down around 8-10 volts your bike could benefit from doing a simple wiring bypass using a 12 volt automobile relay. 5. Read up on it at wiredgeorge motorcycle carburetors - Vintage Japanese Motorcycle Carburetor Sales, Rebuilding and Restoration - Home. 6. New sparkplug wires and sparkplug caps can also improve the spark energy.
Mike Folks |
#4 (permalink) | |
Turtle Wax Taster
This is a common mis-fire culprit. What i've done in the past is pull, the fuel tank, and run the bike at night, in pitch black and you might be able to see spark jump from a bad wire.... crude but sometimes effective ! Rich
Bikes: '07 YZ450F '01 KX500 '84 GPz1100 '82 GS1100E '06 HD Fatboy |
#5 (permalink) |
Well guys i checked the sparkpluge wires. and the pluge wires ends were cracked and broken. cut off a little bit of the wire ends and reinstalled the sparkpluge caps and she made a big diffrence now the miss is almost gone now i will check the valve clearance will keep you guys informed. thanks .
| ninja 500 simple idle setting | mor2bz | The Mechanics Corner | 6 | 09-20-2007 03:05 PM |
| 93 ZX7 rough idle and possible miss fires | Alairson29 | The Mechanics Corner | 1 | 08-06-2007 01:18 AM |
| Mean Streak Low idle pitfalls? | uf-engineer | Kawasaki Cruisers | 16 | 07-16-2006 08:44 PM |
| is 1,400 idle ok for 500ex? | 92 z28 | Kawasaki Streetbikes/Sportbikes | 3 | 06-05-2004 11:17 PM |
| Idle is set but running rough, | fenny777 | The Mechanics Corner | 1 | 05-12-2004 06:02 PM |
