Old 10-09-2009   #1 (permalink)
guamster
Default KZ750 Ltd feedback
Hello. I am looking to purchase a 1981 KZ750 Ltd. I don't know anything about these bikes and am hoping that some of you current/previous owners of this machine can pipe in on some of its pros/cons. The person selling it is asking $500 for it. As far as the condition of the bike, it looks really clean (i.e. no rust, no grease on engine, chrome shiny, etc). Current owner for sale ad is as follows "1981 KZ750 for sale, good clean bike 14K miles needs some carb work". Owner has indicated that he thinks that the floats need to be adjusted and because of this bike is leaking fuel. The bike has a clean title. I am not afraid to work on older bikes. I guess what I am asking is are these bikes robust from a longevity point of view and are parts readily available for them?
I would use the search engine but don't have a lot of time to spend researching as the only opportunity that I have to go and see this bike is this afternoon after work.
I am attaching a picture of the bike. The picture indicates 'LTD' on the side cover.
If you can give me some feedback on this I would greatly appreciate it.
Last edited by guamster : 10-09-2009 at 10:21 AM. Reason: Could have been more concise.
guamster is offline   Reply With Quote
Old 10-09-2009   #2 (permalink)
herk
bustedfeet
herk's Avatar
The carbs probably just need a simple cleaning.
Does the bike run? Going by the photo $500 seems reasonable.
If it hasn't been maintianed, expect to spend another $500 or so to get it road worthy. Add another $200-300 for tires if needed. The Ltd handlebars aren't very comfortable - they force your elbows into your sides - replacing them is very doable, no big deal.
herk is offline   Reply With Quote
Old 10-09-2009   #3 (permalink)
squawk
Finally Got Into First Gear
Just bought my 1980 KZ750 LTD for $900.00 and love it, it runs great. And from what I've seen so far thre are plenty of parts for them out there and plenty of help from folks on this site. I would not have to think twice to buy one for $500.00. Do keep in mind that as herk said you will have to put some money into it and it will require some work but it will be worth it in the end.
squawk is offline   Reply With Quote
Old 10-09-2009   #4 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
2 words...grab it.
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
Old 10-09-2009   #5 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
Some carb cleaning information:
Carb Cleaning 101
By M. Shively
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
__________________________________________________ ____________
I got this from another forum about using Lemon Juice as a carb cleaner:
Lemon Juice Carb Cleaning
If it was me, I'd pull the top covers off, pull the slides out, drop off the bottom bowls, remove pilots/mains. Then with the rest of the carbs still assembled boil them in some lemon juice. You'll need a big roaster pan, a little over a gallon of lemon juice (cooking supply stores), and an understanding wife/girlfriend cause the sh*ts gonna stink a little.
Boil them for about 15 minutes, then rinse them really well and blow them dry with compressed air (make sure all passages are clean). You'll be amazed at how clean they come in that short of a time.
I just did a set yesterday after hearing about it from a buddy who's used lemon juice on a couple dozen racks of carbs. After a couple of minutes at slow boil the lemon juice starts to foam up a little (careful not to boil over) and you can see all the sh*t just dissolving.
After boiling them for 15 minutes (might have to roll them around once to make sure you get the entire carbs) rinse them really well and blow them dry with compressed air. The carb bodies will be kinda chalky looking at this point. I used a toothbrush and PB blaster to put a little luster back into them and then put my internals back in.
I had pulled the bowls off, removed the floats, float needles and seats, jets, and air/pilot screws as well as the top covers and slides just to make sure no crap got itself wedged inside those passages.
After putting the carbs back together and bolting them up not only do they look great but the bikes running MUCH better with all the jet passages finally cleaned out.
I've read/heard somewhere that the same results can be obtained using distilled water instead of Lemon Juice.
Mike Folks
Old 10-09-2009   #6 (permalink)
Kawasaki_Boy
Kawasaki_Boy's Avatar
i would suggest that you get it...and try to haggle a bit. if they're asking 5 they might go to 350 or 4. even at 5, as long as it turns over good with good compression its a deal. cleaning carbs is easy, use an old toothbrush and compressed air. let us know how ya make out
Kawasaki_Boy is offline   Reply With Quote
Old 10-09-2009   #7 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
I got one for FREE. With paper. Delivered.
Repaired and maintained correctly, you will never need to buy another bike. They're that good.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 10-10-2009   #8 (permalink)
vinnye
Turtle Wax Taster
vinnye's Avatar
Buy it!
I had a 750LTD for a couple of years nearly 20 years ago and loved it! Only sold it because I neede a car for my job and could not afford a car and a bike back the.
The carbs sound like they need a clean up (as previously posted).
I would add - fit an in-line fuel filter to the fuel line. This is quite an old bike and the gas tank may have rust / debris in it, the fuel line itself may be rotting and dropping crap into the carbs. So clean out the tank, replace the fuel pipe and maybe the fuel tap?
Get the carbs clean and keep them clean!
UK - South Yorkshire
vinnye is offline   Reply With Quote
KZ750 LTD starting issues glyptodon Vintage Motorcyle Info 0 05-08-2009 09:13 PM
76 KZ750 hard to start and now clutch won't quite let go. Ashbane Vintage Motorcyle Info 13 08-12-2008 12:18 AM
KZ750? or not... jharold Vintage Motorcyle Info 42 07-30-2008 03:53 PM
GPZ750 oil/cooler mount on KZ750??? Freak Daddy Vintage Motorcyle Info 3 12-22-2007 12:55 PM
Feedback on Pipes RDap98 Kawasaki Cruisers 0 03-10-2007 11:20 PM
