Old 10-09-2009   #1 (permalink)
squawk
Default Oil Leak
I just found an oil leak coming from where the shifter comes out of the transmission. However, in looking at the parts diagram for the gear shifter I don't see where there is an o-ring behind it so what's keeping it from leaking in the first place.
squawk is offline   Reply With Quote
Old 10-09-2009   #2 (permalink)
herk
bustedfeet
herk's Avatar
The Engine Covers diagram will show an oil seal.
I believe you can replace it without removing the cover - not sure though.
herk is offline   Reply With Quote
Old 10-09-2009   #3 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
Usually you can take a pick or something similar and remove them without pulling the cover.
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
Oil... Completely Off Topic... kawichic Off Topic 20 12-12-2008 08:57 AM
in the mail - Vulcan 2000 Oil Level Check Procedure Spok Kawasaki Cruisers 22 11-05-2008 12:19 PM
Loss of tanker deal to French/Germans BikerBeagle Off Topic 66 07-18-2008 11:45 AM
Oil Change Instructions BigJohn Off Topic 20 03-24-2008 12:56 PM
oil leak @ oil sensor? Trial'n'Error The Mechanics Corner 1 09-07-2007 01:32 AM
