LinkBack | Thread Tools |
Turtle Wax Taster
Gents: Prettying up my 1981 KZ550A2, I've used black hi-temp engine enamel on the cam cover, and from past use on other bike's cylinders' I'm confident it will take the heat. But, for the black background of the KZ550's ignition cover and alternator cover, I used regular black polyurethane. Do you think the regular polyurethane will take the heat on the covers? Or will it turn grey and peel off? Any experience to share? Thanks.
Sarnia, Ontario, Canada 1981 KZ550A2 2003 ZR7S 1980 KZ1000Police Wanted |
Needs A Real Job
I use the PJ-1 engine paint on my cooling fins and exhaust system, except for an occasional touch up now and then, it's lasted a long time.
I think it's called "Fast Black" I believe they also make a wrinkle paint if you want that look. Motorcycle Chemicals & Lubricants - Motorcycle Paints - PJ-1 Satin Black Engine Paint - 11 oz. - CBXManMotorcycles.com PJ1 Gloss Black Barrel and Engine Paint :: Spray & Touch Up Paint :: Solo Moto Parts
Mike Folks |
#3 (permalink) | |
bustedfeet
Just curious... why didn't you use the stuff that has been proven to work? I painted my engine cap covers w DupliColor hi-temp engine enamel - it has worked well. ![]() |
#4 (permalink) |
Turtle Wax Taster
Gents: I have painted the covers already with polyurethane. The engine enamel is a spay can and I can't seem to find it in a can for brush work. I tried spraying the brush then painted with the fine tipped brush, but this was clumbsy and the spray cured too fast for this tedious work. If the polyurethane is killed by heat, I'll keep experimenting.
#5 (permalink) | |
#7 (permalink) |
bustedfeet
Here's how I sprayed mine.
Clean & polish the cover. Don't polish the black area, of course. Haphazardly mask the perimeter w masking tape. Apply a light coating of bearing grease to the raised lettering etc by lightly patting the grease w your finger then applying the grease to the cover by lightly patting the lettering. Then spray. After the paint dries to the touch, wipe off the raised areas & remove the masking tape. Then wipe off any overspary if necessary. The paint should come right off the greased & polished areas. |
#8 (permalink) |
Turtle Wax Taster
Gents: The small little detail brush seemed less work than the grease, and a whole lot less work than making the detail with tape. De-pressurizing the spray can makes some sense, especially as it nears empty anyway. But I might do that with 6 pumps on my Crossman.
#9 (permalink) |
Finally Got Into First Gear
A couple years ago, I used the virtually the exact same method that herk described, except I used Vaseline as the "masking". And I got virtually the exact same results as he posted in his picture above, except I didn't polish the aluminum nearly as well as he did (sure wish I did now!
This method MIGHT take all of two minutes to accomplish...you just have to be a little careful to keep the grease/Vaseline from creeping off the lines and letters. Although I never would have thought of punching a hole in an aerosol can, it's not a bad idea. Pat
'82 CSR 650 Congressman Jack Murtha called me a racist and a redneck...well, DUH! |
#10 (permalink) |
bustedfeet
Do whatever you want. My method was simple & fast.
Edit: In case you misunderstood I only masked the outer perimeter of the alternator cover. I did it real quick in a haphazard manner. I did not mask the lettering or any other raised areas. I applied the tape first, then the grease. Then sprayed. Fast & simple. ... ... Last edited by herk : 10-11-2009 at 10:03 PM. |
#11 (permalink) |
itching to ride
I would pull the cover, mask around the shiney part, grease the letters and fake fins, and spray away. But I am just simple like that. It takes very little paint so why ruin a whole can?
Oh and I would use a q-tip to spread the vaseline.
1983 gpz 750 .....the wait is over |
#12 (permalink) |
Turtle Wax Taster
I used this paint on my GS1100's engine, it's great stuff:
Amazon.com: VHT Clear Coat High Temp Polyurethane Wheel Coating: Automotive And i've also used this paint for a semi-flat black engine base paint: Rust-Oleum High Heat Spray Enamel - BIC Warehouse The hi-temp Rustoleum is a reall good paint that lasts a long time. Remember, the difference between a pi$$ poor paint job and a professional looking paint job is the quality of the preparation.
Bikes: '07 YZ450F '01 KX500 '84 GPz1100 '82 GS1100E '06 HD Fatboy Last edited by Polar_Bus : 10-14-2009 at 08:25 PM. |
#13 (permalink) |
Turtle Wax Taster
Polar: Thanks for the recommendations. The high temp paints are pretty good these days. My latest experience is with the cast iron cylinders on and old Triumph Bonneville which stayed intact and glossy.
#14 (permalink) |
bustedfeet
Something else I do is to bake the parts in a low temp oven to cure the paint: muffler brackets, brake caliper, wheels, etc. I paint the hidden side of chrome parts w bar-b-que grill paint to deter corrosion: headlite bucket, muffler heat shields, fenders, etc. I topcoated the underside of a rear fender w 3M rubberized undercoating. Not sure how the heat would affect chrome, so I've never baked one of those parts.
#15 (permalink) |
itching to ride
Anyone try this stuff?
Krylon: Products: BBQ & Stove Paints The local wallyworld carries it and I though about using it on my engine.
#16 (permalink) |
Turtle Wax Taster
Not sure, but I think these BBQ and stove paints are somewhat flat finished. I like the gloss because it is easier to clean and looks good to those of us with "Crow Syndrome". The "old quality" gloss heat resistant paints used to turn a bit gray and flat, so I hope the modern ones are improved in this regard.
#17 (permalink) |
Made It To Second Gear
After recently finishing a spray can overhaul on a mates motoguzzi, i can tell you all that the best way to mask off large areas is to cover everything that you dont wont painted in aluminium foil.Yes thats right, the roll that everyone has in the kitchen.Its cheap, quick to apply,it covers everything, & is easy to remove.Use masking tape when you need a fine line. or just spray with a piece of cardboard in hand & spray against it.Make sue that everything is cleaned down with degreaser,or mineral turps.A light sanding & dry off, then paint.It will stick.For how long depends on the application.I use engine enamel on all things hot.VHT exhaust paint on exhaust pipes after sandblasting. And it all looks great good luck. wayno 1500 drifter
#18 (permalink) | |
itching to ride
#19 (permalink) | |
bustedfeet
Something I forgot to mention is that a way to paint by hand using rattle cans is to spray the paint into a small plastic container until it puddles, then use a brush to apply it. This way gives plenty of working time & doesn't waste much paint - I've done it to do touch-ups. |
#20 (permalink) |
Turtle Wax Taster
Herk: I've not run the bike yet. It is pretty well in large restored lumps in the basement. I'm just setting the valves and trying to get the engine in good shape. My target maiden voyage date is July 2010. Meanwhile my 1978 SR500E will have to pull me around. Late Fall has the Canadian riding season coming to a quick close.
| types of paint | Arkainzeye | Kawasaki Cruisers | 8 | 11-25-2007 09:21 PM |
| Canadian paint codes/colours | Rickyboy | Kawasaki Streetbikes/Sportbikes | 0 | 09-17-2007 06:18 AM |
| Paint Code help! | aftermath4788 | Kawasaki Streetbikes/Sportbikes | 4 | 09-09-2007 09:54 PM |
| Paint, Paint, Paint | MatSox | Kawasaki Cruisers | 20 | 10-31-2005 02:28 AM |
| Kawasaki Paint | virtualkuz | Kawasaki Streetbikes/Sportbikes | 5 | 06-10-2004 12:59 PM |
