Old 10-12-2009   #1 (permalink)
ChicagoLTD
Default 750CSR wheel on 550LTD
I am wondering if a stock wheel from an 82 KZ750CSR will be a direct match to my 81 KZ550LTD.
Does anyone know this off hand? Im checking parts diagrams right now but i was hoping for a quick answer!
ChicagoLTD is offline   Reply With Quote
Old 10-12-2009   #2 (permalink)
herk
bustedfeet
herk's Avatar
I'm gonna go out on a limb and say that the front wheel is a direct bolt-on. Not sure about the rear.
The 750-CSR front wheel has many of the same parts as the 650-CSR & 550-Ltd. The KZ550-Ltd wheels are a direct fit to the KZ650-CSR - it should work the other way around. So, if A = B & B =C, then A = C. Both CSR models have the same 4-bolt front brake disk. The 750-CSR has 40 spokes per wheel. The 650-CSR has 48.
herk is offline   Reply With Quote
Old 10-12-2009   #3 (permalink)
ChicagoLTD
Thanks, sorry i should have specified in the original post that i was looking for a rear wheel.
But i checked every component in the parts diagram and the Rear is compatible- for anyone else ever wondering!
Old 10-12-2009   #4 (permalink)
herk
bustedfeet
herk's Avatar
If the rear axle, spacers, shock damper, etc are the same then it'll probably fit.
I bet the 750-CSR has the same panel assy as the 650-CSR.
The 650's is interchangeable w the 550 (the 550 panel is black; the 650-CSR's is silver).
21" Front Wheel for a Vulcan 900 Custom -Some Damage drnk_n_publick Accessory Swap Meet 0 10-28-2008 06:00 PM
Wheel Traps Bad Company What I learned today 1 11-27-2006 07:12 PM
Replacement starter relay/solenoid therealSnafoo The Mechanics Corner 13 04-04-2006 10:02 AM
frame polishing theorangezx-7r Kawasaki Streetbikes/Sportbikes 4 09-28-2005 02:22 PM
Help with wheel wobble ('02 Ninja 500R) fhqwhgads The Mechanics Corner 3 05-19-2004 04:56 AM
