Old 10-15-2009   #1 (permalink)
droptail
Foil Inspector
Default GPz1100A2 gen rotor cross ref?
Anyone know what years I should be looking for? I believe the gen cover is the same starting with the Z1. Is it the same for the rotor?
Thanks
'84 GPz1100A2
'83 GS1100ES
'80 CBX1000
'00 GSX1300R (sold)
droptail is offline   Reply With Quote
Old 10-15-2009   #2 (permalink)
keith1
Made It To Second Gear
keith1's Avatar
you can go to kawasaki.com and get oem part number and then compare it to the early motors, j motor,mk2 and such....might take ya a little while....
1978 KZ1000LTD B-2
10.5-1 1075 KIT
ANDREWS 2X CAMS
29MM SMOOTHBORES
keith1 is offline   Reply With Quote
Old 10-15-2009   #3 (permalink)
herk
bustedfeet
herk's Avatar
Originally Posted by keith1 View Post
you can go to kawasaki.com and get oem part number and then compare it to the early motors, j motor,mk2 and such.... ....
Once in the diagrams, clicking the part number opens a new window w other info, click the yellow/black ? for the cross-reference.
herk is offline   Reply With Quote
Old 4 Weeks Ago   #4 (permalink)
droptail
Foil Inspector
thanks
'84 GPz1100A2
'83 GS1100ES
'80 CBX1000
'00 GSX1300R (sold)
EX500 1st gen to 2nd gen rear brake??? jaydub77 The Mechanics Corner 1 04-29-2008 06:59 AM
ex500 Gen 1 CDI with Gen 2 engine, ? ignition mepasha The Mechanics Corner 5 03-29-2007 03:24 AM
