Old 4 Weeks Ago   #1 (permalink)
jsuwinski
Ol' Time GPz750
Default 83 GPz750 Jumping out of second gear
Has anyone experienced the transmission jumping out of second gear into neutral on a GPz750?
All the gears shift great, but every once in a while, normally under engine breaking, second just jumps to neutral.
Any ideas what's the cause or the fix?
Cheers, John
83 GPz750-A1
81 CB900c ("Bobber" project)
jsuwinski is offline   Reply With Quote
Old 4 Weeks Ago   #2 (permalink)
CaliGPZ
My '82 does this as well but only under hard engine decelleration. If I romp on it in second and then back off quick, she will jump back into neutral. Kind of a pain...Not sure what the cause is or the fix. My bike has 42K on it. May have had a rough childhood!
CaliGPZ
1982 KZ750R1
1973 RD350
(and a bunch of dirt bikes)
CaliGPZ is offline   Reply With Quote
Old 4 Weeks Ago   #3 (permalink)
jsuwinski
Ol' Time GPz750
Sounds like the very same problem as me ...
Cheers, John
83 GPz750-A1
Old 4 Weeks Ago   #4 (permalink)
steell
This space for rent
Sounds like the edges of the shift dogs may be rounded.
I have a 550 transmission handy so I'll try to take a pic to illustrate later tonight.
steell is offline   Reply With Quote
Old 4 Weeks Ago   #5 (permalink)
kopcicle
obstification engineer
kopcicle's Avatar
Send a message via ICQ to kopcicle Send a message via AIM to kopcicle Send a message via MSN to kopcicle Send a message via Yahoo to kopcicle
Engine out , case split , replace at least two gears . Steell or I can point you at the parts diagram or in his case actual photos . This is common for a transmission that has been abused .
~kop
91 KZ1000 POLICE
84 ZN1300 Battlestar Gigantica
79 XS650 Cox Glow Fuel
75 RD 250 Grenade
kopcicle is offline   Reply With Quote
Old 4 Weeks Ago   #6 (permalink)
ratvespa
Top Gear Full Throttle
ratvespa's Avatar
~kop
and also be happy you are not on a yamaha from the 80's, they are known for completely loosing 2nd gear. I always found it funny that yamaha would never admit to that problem, and so many of their bikes from the 80's had that problem.
ratvespa is offline   Reply With Quote
Old 4 Weeks Ago   #7 (permalink)
CaliGPZ
Crap, not what I wanted to hear. Guess I will live with it untill it gets so bad I gotta fix it!!
CaliGPZ
1982 KZ750R1
1973 RD350
Old 4 Weeks Ago   #8 (permalink)
kopcicle
kopcicle's Avatar
Fix it . So bad you have to fix it results in bent shift forks , mangled shift mechanism and the possibility of bits of hardened steel gear teeth attempting to find their way at minimum through the gear clusters and at worst toward daylight .
~kop
91 KZ1000 POLICE
75 RD 250 Grenade
Old 4 Weeks Ago   #9 (permalink)
kopcicle
kopcicle's Avatar
refer to the manual and or a competent parts/service person for the correct parts . You may think that it is mainshaft and countershaft 2nd gear but that is not the case . Mahap Steell could enlighten you as I've run out of time ..
~kop
91 KZ1000 POLICE
75 RD 250 Grenade
3010 jumping out of gear okieduc104 Beartooth Kawasaki 2 03-31-2009 08:10 PM
Can't change gear baza16 The Mechanics Corner 3 03-31-2009 03:33 PM
94 vulcan 750 no second gear larrycavan The Mechanics Corner 6 02-05-2006 09:21 AM
2001 ZX-6R J2 gear lever/clutch problem? MJ The Mechanics Corner 2 11-19-2004 01:05 PM
KX65 jumping out of gear. Please Help. thehardway The Mechanics Corner 1 11-15-2004 08:28 PM
