Hi All:
So I've cleaned and rebuilt my spare carbs. Finished removing all the FI components. Oh... who's bright idea was it to mount the fuel pump retaining bolt in that most of awkward locations, behind the swing arm pivot, under the fuel pump, just above the rear shock. My hands took a beating on that one. Any how, It occurred to me that the fuel petcock does not have a vacuum enable circuit like a lot of carb equiped bikes had. Am I wrong in saying that there is no positive way to shut the fuel off to carbs, once you swap out the FI for a carb set up? My first thought was to use the fuel petcock on my GPz750 tank. But that obviously doesn't work. Any ideas, suggestions, recommendations? Maybe I should post a picture of this GPz of mine... Thanks for the help.
84 GPz 1100 84 GPz 750 86 FZ600 98 VTR 1000 78 GS1000 |
KZ Addicted (needs Help)
I have the same bike and have done this swap. Assuming you have the stock petcock there will be no issues. You should have 3 positions on it off, on and reserve. The only thing you will have to do is to plug the return fitting on the right siide of the fuel tank. I just used a bolt shoved into a piece of hose and used a couple of hose clamps. These are great running bikes and are a lot of fun to ride.
80 Z-1 Classic 84 GPZ1100 77&79 1000 LTD 76 KZ900 KZ750 X 2 KZ650 X 7 KZ550 X3 305 CSR |
#4 (permalink) |
"Off"? Is there an "off" on the original petcock? And I thought my wife was exaggerating when she said I don't look for things hard enough. I'll take another look. Thanks
I haven't actually ridden the GPz1100 I have. But soon...
| Vn 1500 carb Vs Harley carb | AjtheGr8 | Kawasaki Cruisers | 13 | 07-10-2009 01:03 PM |
| 1983 KZ550 LTD carb issues. Please help! | The5thMan | Vintage Motorcyle Info | 2 | 04-18-2009 07:08 PM |
| KZ900 Carb Swap | dgo | Vintage Motorcyle Info | 2 | 04-08-2009 09:42 AM |
| A carb Question | ashbotha | Kawasaki Motocross and Offroad | 2 | 03-04-2009 02:52 AM |
| 92 ninja 600R carb won't stay connected? | ctdubbin | Kawasaki Streetbikes/Sportbikes | 7 | 08-09-2008 11:00 PM |
