Old 3 Weeks Ago   #1 (permalink)
vinnie9000
Default knocking
I'm new to the site and need some advice. The bike is an 84 KZ700 with around 7k miles on it. I've done most of the basic maint. on the bike such as oil, brakes, cables, plugs. The compression sits right around 150 on all 4 cylinders. When I start it up cold, I get a heavy knocking noise YouTube - KZ700 running . It goes away after 10 min or so of riding, but I really do like this bike and want to make sure it's not anything serious. Any ideas on what might be the cause?
vinnie9000 is offline   Reply With Quote
Old 3 Weeks Ago   #2 (permalink)
steell
This space for rent
I listened to the video and couldn't pick the knocking out of the rest of the noise.
Get a 3 foot section of garden hose, place one end against your ear and move the other end around the motor to locate the place where the noise is loudest. That will localize the noise and allow me to probably identify it.
steell is online now   Reply With Quote
Old 3 Weeks Ago   #3 (permalink)
vinnie9000
actually the rest of the noise was my issue. There aren't many older bikes like this around where I live and I'm not sure what noises are acceptable and which aren't. Does the bike sound ok?
Old 3 Weeks Ago   #4 (permalink)
steell
This space for rent
Most of the newer bikes are water cooled, and that makes them a lot quieter than the air cooled KZ fours.
I couldn't hear anything that would give me reason to be concerned, but things sound a lot different when they're right in front of me
Old 3 Weeks Ago   #5 (permalink)
vinnie9000
Thanks!!
Old 3 Weeks Ago   #6 (permalink)
kawpaul
itching to ride
kawpaul's Avatar
I would do the hose check trick that steell mentioned and see if you can locate exactly where it is coming from. These bikes do have a bit of valve noise at idle which is perfectly normal. Also you may be getting a bit of primary chain noise. You really need to isolate where it is coming from. If it is coming from deep within the engine then that needs further investigating. If it is coming from the valve/head cover area it is probably the valves.
Also with the tank on it is hard to tell exactly where the noise originates from because the sound will bounce off the tank.
1983 gpz 750 .....the wait is over
kawpaul is offline   Reply With Quote
loud knocking coming from my clutch/transmission? kbo Kawasaki Cruisers 90 06-02-2009 10:25 PM
Bayou 300 4x4 knocking 300Bayou Kawasaki ATV and Mule 17 03-05-2009 09:06 AM
04 Prairie 360 Knocking when Idling and Belt Light on. RUSigX Kawasaki ATV and Mule 7 02-09-2009 12:40 PM
Top End Knocking demon_soul The Mechanics Corner 3 07-30-2006 12:29 PM
Zxr 250 Knocking Problem james england The Mechanics Corner 0 04-14-2006 01:31 PM
