Old 3 Weeks Ago   #1 (permalink)
HANK62042
Default '77 Kz1000
Just purchased this bike & it's becoming a money pit. Needs carbs & am wondering if 26mm carbs from '76 KZ900 will work.
Thanks
HANK62042 is offline   Reply With Quote
Old 3 Weeks Ago   #2 (permalink)
zoro
GHOSTRIDER
zoro's Avatar
Send a message via Yahoo to zoro
They should, but they wont flow the volume the 28s do.
"GHOSTRIDER" 1980 KZ1000ST-E2
zoro is offline   Reply With Quote
Old 3 Weeks Ago   #3 (permalink)
HANK62042
Thank you! The bike runs rich with the current carbs & fouls plugs quickly.
My shop tells me they've been altered (needle jets) & has no idea what to do.
Old 3 Weeks Ago   #4 (permalink)
StarGate
StarGate's Avatar
Does your bike have any mods like exhaust/intake or engine? Have you checked to see if your current carbs have the correct jets?
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 3 Weeks Ago   #5 (permalink)
HANK62042
Default '77 Kz1000
It's running straights pipes without mufflers & the air box was revoved & it's running with 4 pod type air cleaners.
Old 3 Weeks Ago   #6 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
I'd also suggest changing the sparkplug caps,(they unscrew from the sparkplug wires) and the sparkplug wires. Most car speed shops sell 7MM sparkplug wires by the foot, others may have kits.
If the plug wires are sealed to the coils,I'd use this: Z1 Enterprises, Inc. - Product Catalog to add new plug wires to old ones.
Another place to look if you think it's carb problems would be the input votage to the ignition coils. Low voltage will result in black carbon fouled plugs having you tear down and play with jet sizes.
The website wiredgeorge motorcycle carburetors - Vintage Japanese Motorcycle Carburetor Sales, Rebuilding and Restoration - Home shows a simple wiring modification that bypasses the aged wiring in these older bikes. To see if your bike could benefit from this, do this:
1.Fully charge the battery.
2.Remove the gas tank.
3.With ignition switch in the on position and the run/stop switch in run.
4.Use a mutimeter(Digital or Analog) check the primary side(small wires) of the ignition coils.
5. If it's down around 7-10 volts, your bike is suffering voltage/current drop affecting the spark energy.
Mike Folks
Old 3 Weeks Ago   #7 (permalink)
StarGate
StarGate's Avatar
You should be able to get the proper jetting for that setup with the original carbs. It takes some work and trial n error testing but thats going to be the case no matter what carbs you go with.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 3 Weeks Ago   #8 (permalink)
Mcdroid
Made It To Second Gear
Thanks
Your bike, if stock, has 26's on it already. 1977/78 KZ1000's had 26 Mikuni's and they went to 28's in 1979. The 26's from a 1976 KZ900 should be fine.
1982 GPz750
1982 GPz1100
1977 KZ1000A
1975 Z2A
Mcdroid is offline   Reply With Quote
Old 3 Weeks Ago   #9 (permalink)
Mcdroid
Sounds like you need to change shops...
1982 GPz750
1982 GPz1100
1977 KZ1000A
1975 Z2A
Old 3 Weeks Ago   #10 (permalink)
keith1
keith1's Avatar
Thanks
are your carbs not rebuildable?
1978 KZ1000LTD B-2
10.5-1 1075 KIT
ANDREWS 2X CAMS
29MM SMOOTHBORES
keith1 is offline   Reply With Quote
Old 3 Weeks Ago   #11 (permalink)
keith1
keith1's Avatar
i second that one....
1978 KZ1000LTD B-2
10.5-1 1075 KIT
ANDREWS 2X CAMS
29MM SMOOTHBORES
1st KZ1000 classic for sale. Lee Hester Vintage Motorcyle Info 5 3 Weeks Ago 04:21 PM
WTB KZ1000 police windshield fairing oryhara Vintage Motorcyle Info 3 04-06-2009 12:54 PM
Wanted 1979 KZ1000 LTD tank black with theese Decals ( see post) coloradoKZ Vintage Motorcyle Info 0 03-22-2009 11:50 PM
1994 KZ1000 P - High idle downtownben The Mechanics Corner 5 02-17-2009 08:46 PM
'82 Kz1000 J2 kawisteve Vintage Motorcyle Info 5 04-14-2008 08:28 PM
