Old 2 Weeks Ago   #1 (permalink)
bbb
Default HELP!! (again) 82 KZ1100D
Would any of you happen to know the carburetor base point (rich/lean) setting for a 1982 Kawa Spectre KZ1100D? Am I correct to assume it is the large screw (with nob) located under and between carbs 2 and 3?
This is turning into a complete NIGHTMARE!!
Any and ALL help/direction is VERY much appreciated.
Don
bbb is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
steell
This space for rent
The large screw with knob located between carbs 2 and 3 is the idle rpm setting screw, screw in to increase idle, screw out to decrease idle rpm.
I can't even begin to describe carb tuning to you, you need a manual.
Since all you want is carb tuning info, is it safe to assume that you're an expert mechanic and have diagnosed the problem correctly?
If not, then a description of the symptoms might be a better place to start.
steell is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
bbb
As answer to your questions: First part is while not an expert but a very good mechanic (primarily Harley's). This project was passed on to me by a friend?As for diagnoses.......this bike has been in a barn for quite some time, and previous owner (out of Seattle), had messed with it to no end. It had been exposed to weather elements (no cover, garage etc) before new owner purchased bike now located in Texas. When I opened right side where rotor etc were located, the interior looked as though it had been submerged in a swamp! That has since been cleaned up etc. Attempt to start bike resulted in sputter......... That was it. Yes fuel system has been purged and fresh clean fuel in system and flowing to carbs. Bike has other issues but none that would hinder motor op. So there you have it. As for Idle screw set, where would a good base point be to at least get this beast to fire up???
Thanks for help.
Don
Old 2 Weeks Ago   #4 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
Your bike probably has electronic ignition and may be damaged by water intrusion. Before getting into carb rebuilding, I'd suggest seeing if the ignition system is working properly.
Do this check on the pick up coils(Kawasaki calls them pulsar coils):
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multimeter set on OHMS and range of X 100 check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S” electronic ignition system from Z1 Enterprises, Inc. - Specializing in Vintage Japanese Motorcycle Parts It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
Mike Folks
Old 2 Weeks Ago   #5 (permalink)
StarGate
StarGate's Avatar
If everything else is in order it should fire up and run a 1.5 turns out from lightly seated. Once you get it running you will have to fine tune that adjustment but with proper jetting installed that should allow you to get it started.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
StarGate is online now   Reply With Quote
Old 2 Weeks Ago   #6 (permalink)
steell
This space for rent
I notice that you say there is fresh clean fuel flowing "to" carbs, and there is nothing there that mentions the carbs being disassembled and cleaned.
Considering the amount of time the bike sat, and the condition of the bike, I suggest removing the carbs for a thorough cleaning.
You can either remove the carbs and give them a extremely detailed cleaning, or do it again and again until you get it right. I have tried to take shortcuts on carb cleaning in the past, and it "always" came back to bite me
Old 2 Weeks Ago   #7 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
Carb Cleaning 101
By M. Shively
The elements of internal combustion engines are: correct fuel/air ratio, spark at right time, and adequate cylinder compression.
There are many passageways and openings to check and clean. All are important in function and when obstructed or not working properly, have subtle to radical effects on engine performance. Vacuum leaks and carburetor synchronization also effect performance and should be inspected and adjusted following the below procedures.
Warning: Remove all rubber parts before you begin. These parts usually include vacuum diaphragms, needle valves, o'rings, hoses, and other parts. Spray cleaners will damage these parts. Do not disassemble individual carbs from the carb bracket.
Air & Fuel Passageways: Trace and learn individual fuel and air circuits from beginning to end. Machines can only drill straight through the cast passageways. To change direction, another angled passageway must be drilled. The union is plugged with a brass or bronze bead. Inspect and clean each passageway with spray cleaner, brushes/pipe cleaners/etc, and compressed air. Remove any discoloration and debris. Look for spray cleaner to exit from one or more passageways.
Jet Cleaning: Inspect jets by holding to light and look through them. You should see an unobstructed round hole. Clean the jets with one or more of the following: jet cleaning wires, soak solutions, carb spray cleaners and compressed air. Re-inspect jets after cleaning and install when clear of obstructions. Some main jets have paper-like gaskets. Most have metal spacers between the jet and the emulsion tube. Some screw directly into a brass emulsion tube which is machined for a 7mm wrench at its float chamber exposed base.
Inlet Fuel Valve: Inspect the needle valve & spring. Press down the tiny metal rod that protrudes from the butt or float end of the needle valve. The spring should move freely and return the rod to its location. Check the needle valve's seat area for a groove or other wear. It should appear highly polished. Some needle valve seats are rubber and wear may not be visible. Inspect the needle valve jet seat. You can clean the jet seat with Q-tips and semi-chrome polish if necessary.
Carb Body Castings: Blow air through the atmospheric vent holes located on the dome of each float bowl chamber. Air should exit via hoses or brass nipples. Inspect the emulsion tubes and passageways (cast towers that jets thread into) for discoloration and debris. Clean interior emulsion towers with a soft bristle gun cleaning brush. Clean each Venturi (main carb bore).
Needle Jets & Jet Needles: Clean the needle jets, jet needles, and passageway or tower that needle jet screws into. Clean the emulsion tube (pipe between needle jet and main jet) (Main Jet may screw into emulsion tube). Jet needles are part of the throttle slides. See below…
Throttle Slides: There are several types of throttle slides: Mechanical linkage, vacuum, diaphragm, and cable. Disassembling the jet needle from the slide is not always required for cleaning. If you have vacuum piston type throttle slides (large diameter solid metal slide), avoid cleaning the lubrication from sides and caps. If piston type check cap vents and passageways with air. Clean if necessary and re-lube. If you have rubber vacuum throttle diaphragms, inspect for dry-rot, defects, and tears by gently stretching rubber away from center. Do this until all areas around diaphragm have been inspected. Replace any defective part as described above. Clean carb body areas around diaphragm including air passageways and air jets. Diaphragms have a locator loop or tab fabricated into their sealing edge. Observe this locator upon reassembly. Avoid pinching the diaphragm when reinstalling caps.
Fuel Screws: Fuel screws have sharp tapered ends. Carefully turn one fuel screw in while counting the turns until it seats lightly. Warning: These screws are very easily damaged if over tightened into their seats. Record amount of "turns-in" and remove the fuel screw, spring, washer, and o'ring. The fuel screw is part of the enrichment (choke) circuit...clean passageways as described above. When carbs are assembled, spray low PSI compressed air into diaphragm air vents located at intake side of carbs. Throttle slides should rise, then fall when air is removed. Lightly lube external moving linkages. Reinstall carbs and follow through with carburetor synchronization.
Throttle Cables: Lubricate cables periodically. If cables are disconnected from carbs or removed for replacement, etc . . . remember cable routing and ensure proper reinstallation routing. Avoid bread-tying, sharp bends, and pinching cables. Adjust cables so throttle grip has about 5mm of play or throttle slides or butterfly valves may not open completely (full throttle)(wide full open).
Float Bowls: Inspect float bowls for sediment, gum or varnish, crystallization, and defects. Clean all pipes, tubes, passageways, and embedded jets with cleaners and compressed air. Remove and clean the drain screw and area. Inspect bowl gasket and replace if necessary. Clean and inspect overflow pipes and tubes, look for vertical cracks.
Floats: There are several types of float materials: plastic, brass, black composite, tin, and others. Handle floats carefully. Avoid bending, twisting, denting, or other means of mishandling. Most floats are adjustable by bending a small metal tab near the float axle end. Do not change the float adjuster tab unless tuning fuel service levels. Clean metal floats by soaking or by spraying cleaner and wiping clean. Other material type floats may require replacement if cleaning is necessary. Inspect the needle valve (float valve) and seat. Check needle valve's spring loaded pin. It should depress and return smoothly and without resistance. Check the needle valve's tip for a worn groove. Replace needle valve and seat if either symptom exists. These parts wear together and must be replaced as a set.
Synchronization: This is a fine adjustment performed usually and preferably with the carbs installed and the engine running. The unusual part is performed with gauged wire with the carbs on the work bench. Carburetor synchronizing balances Venturi vacuum at the exhaust side of each carburetor, resulting with smooth idling and optimized performance at all throttle openings. Synchronization is checked using a set of gauges which are either air vacuum type or liquid mercury type. The gauges are connected to vacuum ports on the intake manifolds via nipple tubes or if sealed with screws, sync gauge adapters will be needed. With the engine running at temperature, and with a fan or means of forced convection aimed onto the engine, the carbs fuel screws and idle are adjusted, then the synchronization is adjusted via adjustment screws on the carbs. A reserve fuel tank is recommended for convenience of accessing carbs during this procedure. See gauge instructions and repair manuals for detailed use of synchronization gauges.
Notes: While carbs are apart, record the jet sizes. Look for a very small number imprinted on the body of the jets. Verify that numbers are the same for all jets on models with in-line cylinders. A few transverse-4 models and V-engines, the inner and outer carbs use some different size jets and it's important to not mix them up. If you have dial or veneer calipers, measure and record float heights. Perform measurements with floats just touching needle valves, though not depressing the needle valve rods. Replace fuel and vacuum hoses. Be sure to use fuel rated hose for fuel. Install or replace in-line fuel filters. It's a good time to remove and clean interior petcock fuel filters. Inspect carb manifolds for dry-rotting, inspect all clamps and air ducts. Inspect, clean, lube, and/or replace air filter(s).
Lemon Juice Carb Cleaning(Found on the internet)
If it was me, I'd pull the top covers off, pull the slides out, drop off the bottom bowls, remove pilots/mains. Then with the rest of the carbs still assembled boil them in some lemon juice. You'll need a big roaster pan, a little over a gallon of lemon juice (cooking supply stores), and an understanding wife/girlfriend cause the sh*ts gonna stink a little.
Boil them for about 15 minutes, then rinse them really well and blow them dry with compressed air (make sure all passages are clean). You'll be amazed at how clean they come in that short of a time.
I just did a set yesterday after hearing about it from a buddy who's used lemon juice on a couple dozen racks of carbs. After a couple of minutes at slow boil the lemon juice starts to foam up a little (careful not to boil over) and you can see all the sh*t just dissolving.
After boiling them for 15 minutes (might have to roll them around once to make sure you get the entire carbs) rinse them really well and blow them dry with compressed air. The carb bodies will be kinda chalky looking at this point. I used a toothbrush and PB blaster to put a little luster back into them and then put my internals back in.
I had pulled the bowls off, removed the floats, float needles and seats, jets, and air/pilot screws as well as the top covers and slides just to make sure no crap got itself wedged inside those passages.
After putting the carbs back together and bolting them up not only do they look great but the bikes running MUCH better with all the jet passages finally cleaned out.
Mike Folks
Old 2 Weeks Ago   #8 (permalink)
bbb
Default Carbs etc.
Steell, Mike & Stargate,
I really appreciate all the info you've provided. This will definitely take some. As time. Yep......shortcuts will bite. Rather not go there.
Thanks again! I'll keep you posted.
Don
