Old 2 Weeks Ago   #1 (permalink)
AMCQ46
Default KH125 oil leak on output shaft
Hi All,
As the title says, my 1977 KH125A1 has a small oil leak on the gearbox sprocket shaft following the full bottom end rebuild. It only happens on the side stand when the bike is tipped over far enough for the oil level to be above the shaft, but it is making a mess on the garage floor, so I better get it sorted.
This shaft is a splined shaft, and when I stripped it down there was no obvious seal in there, but there is a sleeve that sits between the sprocket and the bearing [or it may go under the bearing, I cant remember now as it was 1 year ago when I did the rebuild].
In the gasket kit I got, there was an o-ring, but as there wasnt one when I took it apart, and I couldnt see how the o-ring would seal the splined shaft, I didnt fit it.
Question.
Has anyone got a x-section view of the output shaft assembled into the bearings and I can see if there should be a seal?
or
Has anyone got a similar vintage bike and knows what should be in there?
Thanks in advance
AMQ
AMCQ
Midlands - UK
77 KH125A1
Honda Firestorm
GasGas EC200 enduro
GasGas TXT pro 250 trials
AMCQ46 is offline   Reply With Quote
Vulcan 800 Oil leak deniska The Mechanics Corner 23 09-25-2009 02:12 AM
in the mail - Vulcan 2000 Oil Level Check Procedure Spok Kawasaki Cruisers 22 11-05-2008 12:19 PM
men's rules for women - wouldn't let the wife see Freakinout Off Topic 48 02-26-2008 10:59 AM
Oil leak iracekx Kawasaki Motocross and Offroad 1 05-22-2007 05:05 AM
How to change oil on 99 ninja 500R mixery2k The Mechanics Corner 8 01-22-2004 07:49 PM
