Old 2 Weeks Ago   #1 (permalink)
Rhettmclaren
Default 1974 G7T Clutch problems
Hi Everyone,
I have got a G7T which I finally got registered after having a lot of trouble proving the bikes origin due to VicRoads having no record of the engine or chassis numbers.
Now, that it on the road and getting a bit of work I have had to replace the clutch cable. After adjustment the clutch is very hard and has to be pulled really hard to disengage the clutch.
After taking the right hand engine cover off and looking at the nylon clutch release screw it appears that to disengage the clutch the screw has to go so far in that it starts to deform the nylon screw housing. Does anyone one know what would fix this problem???
Are the clutch plates too worn?
or is it a clutch spring issue?
I can take some photo's to help illustrate the problem. Is there somewhere to post them on forum?.
Cheers,
Rhett
Melbourne, Australia
Rhettmclaren is offline   Reply With Quote
clutch problems!!!!! firefighter111 Vintage Motorcyle Info 1 06-21-2008 01:06 AM
06 VN 500ltd Clutch problems Aifwikir Kawasaki Cruisers 8 05-24-2008 05:42 PM
Stalling problems when clutch is relased Secret_Spyder The Mechanics Corner 7 02-07-2005 11:28 PM
Clutch Problems... aygee Kawasaki Motocross and Offroad 3 04-29-2004 08:38 PM
89 Ninja kx600r Clutch Problems torque head The Mechanics Corner 1 03-30-2004 02:44 PM
