Old 1 Week Ago   #1 (permalink)
squawk
Default Removing Front Turn Signals
So if I removed the front turn signals but still what my rear signals to work. Is ther any way to re-wire it so that they can still work?
squawk is offline   Reply With Quote
Old 1 Week Ago   #2 (permalink)
northernman
My hat is made of tinfoil
northernman's Avatar
basically you will need more load to get the flasher to work right.
Or else replace rthe flasher with one meant for just half the load, since effectively that waht you will have taking off the front signals.
Hug a person that needs one, not some damn tree you fool.
northernman is offline   Reply With Quote
Old 1 Week Ago   #3 (permalink)
squawk
What about if I connected the 2 front wires to each other. would that pass the load from the front to the reae just as if the front signal was still installed.
or
Re-routing the front wiring to the rear and then I would have running lights and signal in the rear?
Old 1 Week Ago   #4 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
I'd suggest getting a newer electronic flasher, most of them will work regardless of the number of light bulbs in the circuit.
All I see from connecting the circuits together would probably be blown fuses.
For running lights, you'd have to have dual filiment bulbs and a power source like the front signals have. Most Kawasaki's use this color code for electrical circuits:
RED, running or tail light circuit.
BLUE(sometimes with a RED stripe) the brake light circuit.
BLACK with YELLOW stripe, the ground circuit.
Mike Folks
front and back turn signals gpz750 Vintage Motorcyle Info 1 04-08-2008 09:25 PM
Removing Turn Signals 500r Daren Kawasaki Streetbikes/Sportbikes 3 09-27-2007 10:43 AM
EX500 Rear turn signals lancelotvt Kawasaki Streetbikes/Sportbikes 3 05-10-2007 04:02 PM
Front turn signals '05 10R Supraman78 Kawasaki Streetbikes/Sportbikes 0 10-14-2005 12:34 AM
question: replacing front turn signals woodsie831 Kawasaki Cruisers 3 07-22-2005 03:58 PM
