lighting/charging coil help.
+ Reply to Thread
Results 1 to 5 of 5
Thread: lighting/charging coil help.
  1. #1
    Join Date
    May 2010
    Posts
    16
    Default lighting/charging coil help.
    The lighting/charging coil on my 77 ke 125 is black, should i replace it?
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Needs A Real Job BTK Expert
    Join Date
    Mar 2009
    Posts
    2,899
    Default Re: lighting/charging coil help.
    If you are talking about the normally amber colored enamel coating on the copper wire windings, yes, it has been cooked. Even if it meters OK, the coating goes brittle when overheated and with a little vibration, will fail resulting in a winding short.
  4. #3
    Join Date
    May 2010
    Posts
    16
    Is there any way to revive it, or do i need to replace it?
  5. #4
    Join Date
    Mar 2009
    Posts
    2,899
    There is the possibility it could be re-wound, but it may be more cost effective just to replace.
  6. #5
    Join Date
    May 2010
    Posts
    16
    ok thanks for the help I will just buy a new one.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. lighting/charging coil help.
    By mateo in forum Kawasaki Motocross and Offroad
    Last Post: 10-03-2010, 05:01 PM
  2. kx 250 lighting
    By stuart1981 in forum Kawasaki Motocross and Offroad
    Last Post: 06-15-2008, 02:10 PM
  3. 610 lighting
    By cgs0409 in forum Kawasaki ATV and Mule
    Last Post: 06-25-2007, 07:33 PM
  4. Lighting up the sky
    By ussnewco in forum Kawasaki Cruisers
    Last Post: 09-16-2005, 10:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
