fuse block cover for 82 spectre 1100
+ Reply to Thread
Results 1 to 5 of 5
Thread: fuse block cover for 82 spectre 1100
  1. #1
    Foil Inspector BTK Beginner
    Join Date
    Nov 2004
    Posts
    116
    Default fuse block cover for 82 spectre 1100
    Looking for the fuse block cover for an 82spectre 1100. Any suggestions?
    jono82spectre
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Third Gear And Gaining BTK Intermediate DanOz6Five0's Avatar
    Join Date
    Feb 2005
    Location
    West Allis WI
    Posts
    130
    Does it use the old glass type fuses? How many fuses are there?
    Unless you are trying to do a professional restoration the glass fuses are nto recommended anymore as they can be hard to come by when your bike blows a fuse late at night and the only place nearby is a Quickie Mart. You can get blade type fuse blocks at your local autoparts store.
  4. #3
    Guitar nerd BTK Expert cudaosix's Avatar
    Join Date
    Apr 2005
    Location
    Miami, Florida
    Posts
    3,542
    If you have the same type fuses I do, which are the round glass type. A good idea is to change the fuse box to the newer blade type fuses. Their easier to find and the old round glass fuses might look ok but be bad sometimes. I plan on doing this just havent got around to it yet. the fuse box, fuses will cost around $15.
    Over 40 MegaFonzies and rising
    1980 KZ1000
  5. #4
    Join Date
    Apr 2005
    Location
    Miami, Florida
    Posts
    3,542
    DanO types quicker then I do
    1980 KZ1000
  6. #5
    Join Date
    Nov 2004
    Posts
    116
    Thanks All, I found a used block, but now I probably should look for a new blade type box. I had to special order some glass ones from NAPA. and they are shorter, but work. Thanks for the help!
    j
    jono82spectre
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
