Another problem.... Continued
+ Reply to Thread
Results 1 to 8 of 8
Thread: Another problem.... Continued
  1. #1
    Finally Got Into First Gear BTK Beginner
    Join Date
    Mar 2010
    Location
    chippewa falls,Wi
    Posts
    62
    Default Another problem.... Continued
    Well got a 79 kz1000 st (e) had some issues. Replaced the pick up coil with a Dyna S. Repalced the coils with Dyna's. New plug wires(the good ones). Ran great for a 5 mile ride and did the same thing. Just like somebody shut off the spark. Wait fires right up until it gets under load. $350 bucks and I'm nowhere. What else could be doing this? Plugs are new. All that's left is the regulator/rectifier. Could this be causing the trouble. I went through all my wiring and cleaned and didn't find any melted wires or signs of heat. I'm at wits end.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,201
    Default Re: Another problem.... Continued
    Check the right handlebar switch pod for crumbled or failing solder connections, also inside the headlight are many plug in connectors that can get corrosion and become intermittent.
    Cleaning Motorcycle Electrics
    Get some of the De-Oxit electrical contact cleaner and figure on spending a good day going from the front of the bike to the back. It’s a plastic safe cleaner/preservative. Home is their website. Or use any plastic safe electrical contact cleaner(NOT WD-40 !).
    On the older Kawasaki's, a majority of electrical connectors are inside the headlight housing requiring removal of the headlight, then the fun begins.
    Do one set of electrical connectors at a time to avoid mixing up what connects to where. Usually disconnecting, spraying with De-Oxit and reconnecting is about all you'll need.
    However, when encountering the green crud of corrosion, a brass wire brush may be needed on the pins you can reach.
    Some 400-600 grit wet and dry sandpaper strips rolled into a tube should reach the male and female pins in the more difficult to clean connectors.
    Smoker’s pipe cleaners, cotton swabs and wooden toothpicks work as cleaning aids.
    Really small electrical connectors may require the use of a welders tip cleaning tool assortment.
    Most pins in the connectors are coated with a thin plating of tin, and others may be nothing more than copper or brass.
    If moisture is added, the resulting corrosion lowers the voltage/current being carried causing dim lights, slow engine cranking, slow turn signal responce and lower input voltage to the ignition coils resulting in weak spark.
    The left and right handlebar switch pods will need attention too as they have circuit functions like turn, horn, run/stop, and start.
    Usually a spritz or two with actuation of the switch is about all needed for these switches unless corrosion is detected and then careful disassembly is required.
    The ignition switch may or may be not sealed to allow spraying the internal contacts. I urge caution if attempting to open this up as springs, and ball bearings may fly out never to be seen again!
    If your bike has the older style glass tubed fuses, I suggest replacing them as vibration can cause internal failure. AGX is the type used, and most auto parts stores can get them for you.
    Clean the fuse holder clips, looking for signs of overheating(discolored insulation, signs of melting).
    I use metal polish on a cotton swab, followed by spraying another clean swab with the De-Oxit and then rubbing the inside of the fuse clip.
    All battery cables must be clean and tight for maximum current transfer. Check the cables going from the Negative(-) battery terminal/post to the engine mounting bolt
    Also the one going from the Positive(+) terminal to the starter solenoid and from there to the starter motor.
    If any battery cable feels ”Crunchy” when flexed, replace it as possible corrosion is inside the insulation.
    Each "Bullet Connector" will have to be sprayed to ensure good connectivity, especially the ones going to the energizing coil of the starter solenoid.
    The alternator output “Bullet Connectors” are usually behind the engine sprocket cover and will need inspecting and cleaning too.
    The turn signal light sockets will benefit from a spritz from the contact cleaner along with the tail light/brake light socket.
    Some brake light switches can be sprayed on the actuating rod, with the spray running down inside to the electrical contacts, others may be sealed requiring replacement if the switch is intermittent in operation.
    Some people put the Di-Electric Grease on cleaned terminations/connectors, I don’t, as I’ve read/heard it can cause problems when it gets hot, actually insulating the connections, so the choice is yours to use or not.
    I think I've covered about all of the electrical systems on the bike.........
    Why WD-40 Should Not Be Used On Motorcycle Electrical Items.
    For many years, I was proponent of the use of WD-40 on fuse clips, fuses, switches and connectors. After hearing of other peoples experience with intermittent and sporadic activity, I shrugged it off as maybe they did something wrong in the application of the product.
    It wasn’t until the time I rode my 1982 GPz1100 B2 model to downtown San Diego that I encountered the problems others had gone through.
    After concluding my business downtown, I walked to where my bike was parked, turned the key to unlock the forks, and prepared to start the engine. The key was in the "On" position, yet I had no lights in the dash panel, the fuel pump was not running(I have FI), and the horn and tail light were not working.
    Puzzled as to why nothing electrical was happening, I remember my earlier conversations about how WD-40 will over time become a non-conductor(more like an insulator). I had some pieces of 400 and 600 grit sandpaper in my tool kit and with them was able to scratch away the coating from the WD-40 on the fuses and clips.
    After removing the insulating film, the bike started and ran like it should. Since that time, I’ve told people about the problem with WD-40. If you must use a contact cleaner, I recommend getting some "De-oxit" from Radio Shack Stores or any good electronic supply store.
    Mike Folks
  4. #3
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,201
    Testing Kawasaki Ignition Coils For Input Voltage
    When voltage testing Kawasaki Ignition Coils, the following needs to be done:
    1. Remove the fuel/gas tank to access the coils.
    2. Fully charge the battery.
    3. Using a multimeter, set it up for VDC(Volts, Direct Current), range of 20.
    4. Turn on the ignition switch and the run/stop switch to “Run”.
    5. Put the multimeter’s RED probe on where the red or red/yellow wire goes on the ignition coil.
    6. Put the multimeter’s BLACK probe on either the battery Negative(-) post/terminal or a good frame ground.
    7. You should be able to see battery voltage at the ignition coil connection.
    Ignition Coil Primary And Secondary Wiring
    Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs(your primary wiring may be different). The 550’s,650’s & 750’s are backwards to what is listed for the bigger 4’s.
    The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
    For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
    The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod. Your primary wiring may have a different color.
    The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs.
    Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
    Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms. These ports are wired together, so it makes no difference which is used, as long as the correct coil to sparkplug configuration is followed.
    The sparkplug caps should read 5K OHMS(5000), any higher, or a reading of infinity means new caps should be ordered.
    To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
    Keep in mind, the wiring is reversed for the 550’s 650‘s and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
    The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
    These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
    Mike Folks
  5. #4
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,201
    I'd get new fuses as the glass tubed ones should be replaced at least once a year. Many a rider has been stranded when a fuse goes out.
    Fuse And Fuse Holder Designations
    1. The older Kawasaki’s use a glass tubed fuse with the designation of AGX 1” long. Most good auto parts stores can get them for you. They are ¼” in diameter.
    2. The more common AGC is 1 ¼” long and may not fit the smaller fuse clips. Again, ¼” in diameter.
    3. To clean and polish the fuse clips, I use a cotton swab(Q- Tip) and some Brasso metal cleaner or Turtle Wax Chrome Polish. I suppose any good metal polish would work.
    4. These fuses can fail internally but look good, only by removing them from the clip and electrically continuity checking with either a self powered test light, or a multimeter set on OHMS can they be determined to be in good shape.
    5. A physical inspection of the metal end caps for tightness will tell you if the fuse is serviceable.
    6. Most modern motorcycles are now using the automobile “Blade” style fuse with the designation of ATC or ATO.
    7. The reduced sized “Mini” Blade style fuse holder uses the ATM size of fuses.
    8. If the fuse and fuse holder overheat, it could soften or aneal the grip of the clip, it might require squeezing the clip to restore the tightness.
    9. A list of where to purchase “Blade” style fuses and holders:
    Waytek Inc, Home page to buy fuses, circuit breakers, cable ties, wire and other electrical supplies By Waytek Inc. Welcome to Waytek Wire
    Susquehanna MotorSports - High Performance Vehicle Lighting and Competition Accessories Susquehanna MotorSports - Auto Performance Product
    6-way fuse blocks
    10. A source for the glass tubed AGX fuses:
    Browsing AGX Fuses
    Mike Folks
  6. #5
    GHOSTRIDER Forum Supporter zoro's Avatar
    Join Date
    Oct 2008
    Location
    Falls City,Nebraska.
    Posts
    2,691
    Quote Originally Posted by nobeer141 View Post
    Are the new Dyna coils 3ohm(green)? Did you bypass the ballast resister under the left side cover? If yes to both questions, then its time to test the igniter. You might also check the valve clearances and for slack in the cam chain.
    "GHOSTRIDER" 1980 KZ1000ST-E2 ~Michael Hill~
  7. #6
    Forensic Bug Splatter Analyst BTK Expert martin-csr's Avatar
    Join Date
    May 2011
    Posts
    1,661
    Default -
  8. #7
    Biker Chef BTK Expert sheldonbourgeoi's Avatar
    Join Date
    Jul 2008
    Location
    Victoria, B.C.
    Posts
    987
    There should be a maintenance book for folks that own vintage Kawasaki's. Title it "Another Problem...Continued."
    If you ride an old Kawasaki chances are you'll ALWAYS be working on it to some extent. I call it the price you pay for riding a classic. I"m willing to pay the price myself.
    Best thing is with guys like Mr.Folks, Zorro, Martin-CSR , Kopsicle and the countless others over here that know these old beasts, the issues always get sorted out, and eventually you become pretty decent at finding and fixing problems as they arise by yourself.
    1984 GPz 750
  9. #8
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,201
    IC Igniter Replacements
    The igniter from any of the following bikes is a direct fit replacement for yours.
    KZ1000-J1 (1981)
    KZ1000-J2 (1982)
    KZ1000-J3 (1983)
    KZ1000-K1 (LTD) (1981)
    KZ1000-K2 (LTD) (1982)
    KZ1000-M1 (CSR) (1981)
    KZ1000-M2 (CSR) (1982)
    KZ1000-P1 (Police 1000) (1982)
    KZ1000-P2 (Police 1000) (1983)
    KZ1000-P3 (Police 1000) (1984)
    KZ1000-P4 (Police 1000) (1985)
    KZ1000-P5 (Police 1000) (1986)
    KZ1000-R1 (Eddie Lawson Replica) (1982)
    KZ1000-R2 (Eddie Lawson Replica) (1983)
    KZ1100-A1 (Shaft) (1981)
    KZ1100-A2 (Shaft) (1982)
    KZ1100-A3 (Shaft) (1983)
    KZ1100-B1 (GPz) (1981)
    KZ1100-B2 (GPz) (1982)
    KZ1100-D1 (Spectre) (1982)
    KZ1100-D2 (Spectre) (1983)
    KZ1100-L1 (LTD Shaft) (1983)
    Also, any igniter with one of the following part #'s will work since the original was superseded by these numbers:
    21119-1356
    21119-1041
    If your bike has the mechanical ignition advancer(look behind a CD sized cover on the right of the engine), it can use the suitable substitute found here: General Motors HEI Ignition Module For GPZ550
    Mike Folks
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Still Around. Sorry For Continued Absence
    By Slo'Poke in forum Off Topic
    Last Post: 08-25-2009, 11:20 AM
  2. KZ1000 Fuel Tap Continued
    By grumpy56 in forum Vintage Motorcyle Info
    Last Post: 01-30-2009, 09:17 PM
  3. KSF 250 Headlight continued...lol
    By ThePhantomone in forum Kawasaki ATV and Mule
    Last Post: 06-02-2008, 07:33 PM
  4. Cool and weird motorcycles (continued)
    By metalesp in forum Off Topic
    Last Post: 05-19-2006, 09:16 AM
  5. Great start...continued (more pic.s)
    By trikebubble in forum Want to show off your ride?
    Last Post: 05-29-2005, 11:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
