While I wait for a response about my coil readings,I decided to check every thing and clean as much as I could. Is there a way to remove these bolts without messing up the phillips head on each? I plan on changing to allen head if I ever get them to budge. I have tried tapping on the screwdriver and I have an older impact driver but these bolts seem welded in there. I have the ones on the brake fluid resevoir that look like the PO tried taking off and the heads are really bad. What next, easy out or just drill them? I was worried about chips falling in and messing something else up. Seems to be my method lately.. Thanks for any info
LinkBack URL
About LinkBacks
