First off, I don't have any reference how old or abused the clutch is in my bike. Anyway, about 1,000 miles into my oil change my clutch has started to slip very noticably in 5th & 6th gear once you hit above 5,000ish RPM and at hard thottle. I can wind out 1-3 up to 7,000 it seems w/o any slipping (or at least any I can notice). I am currently using basic conventional Pennzoil 20w50. Now I know you can't use any oils that have synthetic on a wet clutch because it will cause it to slip. Is this the main reason why the local shop insists I use Kawasaki oil because it does not have any added friction modifiers? (and in case you wanted to know, I work at an oil change shop to pay for my toys & habits)
LinkBack URL
About LinkBacks
