1974 mt1 carb problem - Kawasaki Motorcycle Forums
post #1 of 20 (permalink) Old 03-01-2017, 08:42 PM Thread Starter
Junior Member
I'm having a problem getting gas into the carb. I did some reading in my manual that the needle valve is stuck. I have verified a couple of time the needle valve isn't stuck. Also the carb has been broken down and cleaned, so I'm unsure what it could be any ideas?
Kennys is offline
Sponsored Links
Advertisement
post #2 of 20 (permalink) Old 03-01-2017, 10:26 PM
Senior Member
Jimray23's Avatar
Theres a clog between the carb and tank or in the tank. If it has a filter or filters, check for flow there. If no flow on the supply side, check the valve on the tank and keep goin till u find fuel flowing.
Jimmy
1979 kz1000 ltd mkii
dyna s ignition, dyna 3 ohm coils, solid copper core plugs, full rewire.
Jimray23 is offline
post #3 of 20 (permalink) Old 03-02-2017, 06:41 AM Thread Starter
Junior Member
I pulled the tank twice and was able to verify no restricted flow from it or the gas line. I also broke down the carb and cleaned it a couple of times, still no gas to the carb. Very perplexing to me because I checked the manual and it said stuck needle valve, or like you said clogged gas line. Is there any other issue you think it could be, like an air/vacuum issue? Thanks for responding.
Kennys is offline
post #4 of 20 (permalink) Old 03-02-2017, 07:49 AM
Senior Member
Jimray23's Avatar
If you pull the bowl off your carb and the line off your tank, blow through it and see if theres a change. While your blowing wiggle the float. That will tell you if its the float valve or a vent.
Jimmy
Jimray23 is offline
post #5 of 20 (permalink) Old 03-02-2017, 11:03 AM
Senior Member
Remove fuel line from carb.
Turn on fuel tap.
Do you get sustained flow?
sfair is offline
post #6 of 20 (permalink) Old 03-02-2017, 11:06 AM Thread Starter
Junior Member
Yes the flow is sustained. Gonna pull the carb again tonight and check into what Jim is saying to do. I'm sure it is something small, that I'm missing. I'll keep you two posted.
Kennys is offline
post #7 of 20 (permalink) Old 03-02-2017, 11:51 AM
Senior Member
Why do you think the carb is not filling up?
How did you clean it and with what?
sfair is offline
post #8 of 20 (permalink) Old 03-02-2017, 01:13 PM Thread Starter
Junior Member
I pulled it a couple times after opening the gas line up and it's bone dry. I'm gonna leave carb on and take the bowl off tonight.
Kennys is offline
post #9 of 20 (permalink) Old 03-02-2017, 01:35 PM
Senior Member
See second sentence, post #8.
sfair is offline
post #10 of 20 (permalink) Old 03-02-2017, 03:03 PM
Senior Member
Jimray23's Avatar
I think u mean post #7
Jimmy
Jimray23 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
