1981 Kawasaki 550 LTD - Kawasaki Motorcycle Forums
post #1 of 2 (permalink) Old 04-05-2017, 06:04 PM Thread Starter
Junior Member
I just changed the oil on my 1981 550 ltd. Rode off. Engine sounded great! (always sounds better with new oil). Got to the gas station, and when I clicked it into Neutral, the green light flashed and the bike went dead. Nothing. No electric.
I changed the fuses on the left side of the bike...nothing. I also seems like the foot clutch level now won't even go into any gear?
any ideas? Am I missing something obvious?
Thanks
Doug
DougRichards is offline
Sponsored Links
Advertisement
post #2 of 2 (permalink) Old 04-07-2017, 08:40 AM
Senior Member
martin-csr's Avatar
Just in case. Did you install new fuses in the main fuse box behind the plastic electro cover? There's also an accessory fuse box in plain sight, usually rearward or to the right of the electro cover.
Shift pedal. You have to pull in the clutch lever to shift & you may have to spin the rear wheel. The bike has a positive neutral finder, so when you are in neutral or 1st gear & the rear wheel isn't spinning, you should only be able to shift from neutral to 1st or vice versa.
martin-csr is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
