Old 05-24-2004   #1 (permalink)
Scarybaldguy
Send a message via Yahoo to Scarybaldguy
Default 12-digit VIN?
Hi, new Kaw owner and forum n00b with a possibly stupid question.
The bike in question is a '77 KZ1000. The only thing resembling a VIN on it is a 12-digit code, printed on the mfr label and stamped into the frame where a 17-digit VIN would normally be: KZT00A-012273.
Buykawasaki says that's not a valid VIN/HIN. The bike has no title (plate expired and bike abandoned in 1984, sat in storage until 1997, last owner never bothered to title and reg it), so I can't go by it. Using Uncle Bob's decoder, I've almost developed a 17-digit VIN for it: JK1GU71A?7?012273. Not knowing the check digit or the factory location code, I can't go any further... and it's not on the frame in that form anyway.
Little help here?
Scarybaldguy is offline   Reply With Quote
Old 05-28-2004   #2 (permalink)
jebarber
hey, new Kaw owner and forum noob myself, heh
I don't think the 17 digit VIN standard came around until around 1980 but I may be wrong. My bike is a '73 and the VIN/SN is Z1F-41288
by the way I have the same problem as you, this bike hadn't been registered since '87 and there is no title anywhere to be found. I do have the plate that was on it in '87, I'm hoping that will help some.
jebarber is offline   Reply With Quote
Old 05-28-2004   #3 (permalink)
shift1313
Turtle Wax Taster
Send a message via AIM to shift1313
Default try
KZT00A sounds right for a kz1000 and the A for a model then the 6 digits. frame number should still be on the head stock. and vin range for that year is
KZTOOA500001 - 507026 for the Amodel. usa mfg
KZTOOA000101 - 026623 for the A model japan mfg.
so everything does seem in order. if you go to the dmv they should be able to pull it up. you can also take your engine number, although i dont think it will help. that is located under your carb on the rh engine case. should be fairly obvious. it should be in this range KZTOOAE000101 - 41170.
hope that helps
matt
Matt
83 GPz750
02 DRZ400
shift1313 is offline   Reply With Quote
Old 05-28-2004   #4 (permalink)
Scarybaldguy
Hello gents,
Insurance gave me no hassles at all concerning the VIN, and the verification place didn't look twice, except to comment on how good the bike looks for its age. DMV may be another kettle of tripe entirely.
Thanks,
Coinneach
Old 11-20-2004   #5 (permalink)
elr658
Eddie Lawson is God!
elr658's Avatar
It won't be a problem. That's the way the vins ran back in the day.
1982 Kawasaki KZ1000R1 #658
1983 Honda CB1100F Blue.
www.myspace.com/79cb750f
Old 04-22-2005   #6 (permalink)
rininger42r
I have the same problem, new to road bikes (always had a bike to ride the fields growing up but first time trying to get a bike legal for road use) I on the other hand have the title, the title says the vin is KZ750H009845, I had the bike plated a couple years ago and insured too, but then I put it in storage and just getting it back out, tried calling the insurance company and they say its not a valid VIN, but said just bring the title in and they will make a copy of it just in case there is any question about it being a valid VIN, and somehow I had it plated before so the DMV must have accepted it as a VIN before...
rininger42r is offline   Reply With Quote
Old 04-23-2005   #7 (permalink)
Nate
KZ Kool!
Nate's Avatar
I'd bet you just caught someone whose inexperience caused them to dismiss your VIN without bothering to look it up. All these older bikes have a shorter VIN and there is no way to make it longer.
- Nate >>
"Riding is the reward for time spent wrenching."
"Wrenching is the result of time spent riding!"
KZ650 SR
Nate is offline   Reply With Quote
VIN# help Groundworx Kawasaki Motocross and Offroad 38 05-26-2009 08:55 PM
Location of VIN AqCons Kawasaki Streetbikes/Sportbikes 2 05-01-2006 08:38 AM
scratched vin and no title...goin to the dump eh? soaringchicken Vintage Motorcyle Info 8 07-17-2005 12:50 PM
Where is the VIN camneely8 Kawasaki Streetbikes/Sportbikes 3 07-01-2005 02:27 PM
80's KDX vin decode Rick Kawasaki Motocross and Offroad 3 11-25-2004 09:50 AM
