KZ Krazy
On the points driven bikes, if your battery is low, will you still be able to start it with a kick starter? It seems to me, that you would still need power to the coils through the points unless I am missing something.
Thanks! |
1962 B8 125cc!!
Hi Tazzmann....Yep...you should have no problems starting the bike. The alternator (stator) will generate enough juice to power up the ignition coils. You actually would even be able to start the bike with no battery installed, but you may run the risk of damaging some electrical components, namely light bulbs. Without a battery in the loop, the current generated by the charging system is unregulated, and you'll be feeding all the electrical bits significantly more than 12V at any RPM greater than idle. I made that mistake while servicing my mom's Honda. I fired it up and gave it a little gas and thought......"man that neutral indicator is bright!" Needless to say, a second or two later it went black, along with all the other instrument cluster lights, tailight bulb, and low beam on the headlight. Expensive lesson learned. Good luck.
KZ Krazy
Yeah, I had a battery lead break off this bike and killed all the lights. THAT was fun. Anyway, I guess I can't get enough kick cause I tried starting it without a battery last night and couldn't get it to go. I 'borrowed' the battery from my 440 and it started right up with both the kick and the electric start. Don't know...guess I am too old to kick without a battery assist.
#4 (permalink) |
Can't find time to ride
How much power is that Generator/Alternator gonna produce when you kick start her and it spins 10 times? (if you lucky). Unless your bike is tuned real well, you'll want some battery juice to get her going.
| New member - question for you lads! | Technician | Main Lobby | 20 | 09-30-2006 03:12 PM |
| Tire pressure on meanie question! | wingman01 | Kawasaki Cruisers | 7 | 05-14-2006 09:04 AM |
| need points cam for 78 kz1000 | goatboy | Accessory Swap Meet | 2 | 10-27-2005 05:16 PM |
| Suzuki - 1982 GS550 speedometer and buying question | Stuart | Main Lobby | 3 | 06-01-2004 04:41 PM |
| were are the points & Shop Manual for 1980 KZ750G 2 cyli | kyhick1 | The Mechanics Corner | 4 | 05-19-2004 09:37 AM |
