Old 05-15-2006   #1 (permalink)
Mr Wiggles
Default Sealing carb boots ??
I am not sure if that is what the technical name is for these things..I think they are "rubber intake tubes" that sit between the carbs and the head. These are old and probably leaky. I am wondering if these can be coated with silicon or gasket maker and be used or if they have to be replaced ? I can't find new ones of these for some reason.
Mr Wiggles is offline   Reply With Quote
Old 05-15-2006   #2 (permalink)
forest1000
forest1000's Avatar
What bike do you have?
I want to carry a piece of who I was before
So when I hit the wall, I really hit the wall
86 Ninja 1000R, 84 GPz750
forest1000 is offline   Reply With Quote
Old 05-15-2006   #3 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
what bike ? more than likely 99.99999999999999999999999999999% of the time silicone is just a temp. fix . just spray carb cleaner on the boots one at a time and see if the idle goes up/down. if it does then you have a leak in that vicinity (boot,seal between head/boot,carb side etc.)
QKENUF4U is offline   Reply With Quote
Old 05-16-2006   #4 (permalink)
Mr Wiggles
It is a 1979 KZ650 SR. I found where I can get new boots but they are 35 bucks a piece and I need 4 of them...ouch
Old 05-16-2006   #5 (permalink)
forest1000
forest1000's Avatar
That's pricey. Try what Q says to do. You may not need them.
Old 05-16-2006   #6 (permalink)
wiredgeorge
Vintage Motor Mechanic!
$35 a piece? Bwhahahaha that must be a "special"! Contact www.z1enterprises.com - I suspect they can set you up with new ones for a lot less. If you have ANY cracks, they should be tossed. You might be able to seal the cracks but they will be old and hard and not seal to the head. If you have an air leak in the intake manifolds, there is a real good possibility of holing a piston.
wiredgeorge
Texas Hill Country
wiredgeorge is offline   Reply With Quote
Carb cleaning surprise gpz_rider Vintage Motorcyle Info 11 04-25-2009 08:56 AM
KZ440 carb help babee_huey The Mechanics Corner 7 04-23-2009 11:31 PM
92 ninja 600R carb won't stay connected? ctdubbin Kawasaki Streetbikes/Sportbikes 7 08-09-2008 11:00 PM
Vega Nitro Touring and Sport Boots? SixFiveOh Riding Gear 7 05-22-2008 09:58 PM
idle/carb problems babee_huey Main Lobby 3 08-12-2004 01:34 AM
