Needs A Real Job
The Kawasaki GPz900R (Ninja)
There are times in the history of 'things' when something dramatic occurs, and you also happen to be in the right place to take advantage of the event. This occurred to me with the GPz900. This was intended to be Kawasaki's comeback bike to get back into the ranks of the Superbike elite, and they did it in style. This motorcycle is a classic. I had my example only for a short time, but it made a dramatic impression on me. Details "The Kawasaki GPz900R, a.k.a Ninja... Is a 4 cylinder, water-cooled motorcycle Displaces 908cc Has a double disc brake up front, and one disc at the rear Handling is great, even by today's standards Has a comfortable seat Has a 3.9 gallon (Imperial) fuel tank Gave between 12 and 80 mpg Went off the clock at 165mph Could cruise at 120mph all day Could wheelie at 100mph, purely on power and rough road The 'banana' styling could melt a babes heart at 20 paces Stopped well, accelerated like it was late for a wedding Introduced in 1984, kept in production through 1995 in the UK Failings Eat tyres and brakes. I replaced both at 3000 mile intervals, front and back Getting the rear wheel out was a pain, the eccentric adjuster was awkward to get correctly aligned again At 150mph, consumed fuel like there was no tomorrow, which exaggerated the fuel tanks lack of size The anti-dive front end could get a bit out of shape under really hard braking The steering at the front was a bit strange at times, the 16" wheel being the culprit The fairing and handle bars were a vision of the seating ergonomics that were to come - nasty The hydraulic clutch required quite a pull, even when fully home, this provided me years of carpal tunnel problems Didn't own it long enough Strengths Engine This is a motorcycle built around an engine. It would troll around town in 6th gear at 30mph, or rip up tarmac in 3rd at 9000 rpm. It would cruise, 2 up, at 120mph, down dale and up mountain. When you could control your right hand, fuel consumption figures were genuinely frugal, I managed just under 80mpg on one occasion, though 50mpg was easy to obtain on a regular basis. One particularly adventurous day though, getting down the 120 miles of the A-1 to London in just over the hour, the machine returned about 12mpg; I had to refuel in the middle of the trip... it was unheard of! The engines ability to pull freely in a high gear, from low in the rev range was a god send, particularly on inclement days, but it also worked to the advantage of passengers. On days when I was less concerned with passenger health, I had to remember to get ready to trap the passengers feet in my armpits, or they would be off the back. It was this later symptom that lead me to feel that any future large displacement motorcycle I owned would be a single seater. The handling was excellent, and by the standards of the day, spectacular. Mid-corner bumps rarely phased the bike, but when they did upset it you tended to be going quite fast - 140mph tank slappers are not enjoyable, even on a bike this good. The feeling that you were on rails really made for a pleasant form of mile gobbling; you just pointed the bike in the direction you wanted to go, and sometime later you were there, all fresh and happy to do it again. Rolling up the A68 Jedburgh road at 7am at over 100mph was a ride I will remember for its proof of the bikes stability and agility. Tried and Tested Tyres The original fitment of Japlops were surprisingly good. I tried Dunlop ArrowMax's later but gave up on them when the bike spun the rear at over 100mph. I eventually settled on Metzeler ME-99 rear and ME-33 front, a fitment that was to become standard fare for most Proddie racers. Exhaust Never had to replace the standard exhaust. Seat No significant qualms. Plugs Never replaced the originals. Oil and other consumables I replaced the oil regularly at about 5000 mile intervals. Again, I always had the oil and oil filter replaced at the same time. Early 900's like my one were to suffer from oil related problems, my example never got that far. Brakes Pads were replaced by standard Kawasaki replacements. Suspension There was not a lot to do here. I set the anti-dive to the softest settings and religiously made sure the fork air pressure was in factory spec's. At the rear, I wound the preload to its highest settings and made sure the pressure was at the upper end of the range. To Round Up I did only 13,000 miles in 6 months of ownership before the bike was totaled in an unfortunate accident. It was a missile, it did things that no bike before had done. It could take on anything on the road and make it look like a dead rat: Porsches, Ha! Honda CBX1000's, Suzuki GSX1100's, Honda CBR1100R's, Kawasaki Z750 Turbos's; they were all just play things. Such performance had its penalties: roads that had been challenging on less capable bikes were a simple drone unless taken at elevated speeds, roads that were a challenge normally, were now doubly so if the performance of the bike was to be used. The machine was an education in how performance could be packaged. These were stunning bikes in their day, today they are simply old bikes with a lot to offer. If you should come across one, its probably a good machine to sling a leg over. Just something i though was cool, found it on line , while surfing around." Eric PS. 08-23-2008 The bike is still running just fine. I have had to fix a wire from behind the keyswitch that sends power to the tailight. Starts well after sitting for up to a week, still has a nice shine. The recovering of the seat early last season has held up well, looks factory. The Hindle header has been repacked and modified a bit. It is still a real howler above 7k rpm. Fuel tap is holding up well, I usually rebuild it with the kit from Kawi once a season but putting a bit less miles on it this year. The Michelin Macadams are a great tire, happy with the wear and performance I get from them. Clutch seems bulletproof, chain holding up well, brakes due this fall. Cheers mates!
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! Last edited by Ericthejet : 08-23-2008 at 09:00 AM. Reason: updates added |
#6 (permalink) |
Nice write up! I plan on keeping my '86 for some time. I always tell friends that I wouldn't be going any faster on the street with a ZX9R or ZX10. Got the petcocck leak sorted, and new tires so I'm rolling. Cam chain was getting a bit rattley so I bought a used tensioner on Ebay. Hopefully that will take care of it for now.
#14 (permalink) |
Wrench turner
Isn't $2500 a bit high? I mean, even though most people are gouging on prices, and we are still in a summer riding season, when it was new the bike was only $5000. How can it be $2500 after 24 years?
#16 (permalink) | |
Wrench turner
$2500 seems high to me, but if you've got another fish on the line, more power to you. You must have it in really great shape with low miles. Got any more pictures? |
#18 (permalink) |
Sit speling cheker
Ditto on the "I love my '85 A2".
...Diane '85 ZX900A2 Ninja(modern classic) Mayor & Chief Sanitation Engineer - DooberVille |
#20 (permalink) | |
Needs A Real Job
I have a super clean blue and silver example with a nice pipe and clean plastics. I'd ask $2500 for mine firm.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
| Kawasaki can make you sick. | Uncle Bob | Off Topic | 24 | 01-15-2009 03:00 PM |
| Kawasaki 250cc Rants&Raves Specialist | ZX-2R | Main Lobby | 41 | 10-12-2007 06:06 PM |
| Press Release Issued By Kawasaki Motors (January 5, 2005) | 2WheelFun | Main Lobby | 22 | 09-08-2007 05:36 PM |
| Brake Problems - 1982 Kawasaki GPZ 550 H2 | Cerbera | The Mechanics Corner | 1 | 08-20-2005 12:50 AM |
| Newbie ard here and in 4 stk GPZ 900 R 1984 | gpzracing23 | Main Lobby | 3 | 09-16-2004 09:32 PM |
