1980 kz 1000-e2-shaft
+ Reply to Thread
Results 1 to 6 of 6
Thread: 1980 kz 1000-e2-shaft
  1. #1
    Finally Got Into First Gear BTK Beginner
    Join Date
    Sep 2006
    Posts
    56
    Default 1980 kz 1000-e2-shaft
    i have had this particular machine since jan 1987 and have kept it in decent conditon since then
    i have not driven it in two years since it would not start, I have found that the ballast resistor is defective.
    i am not awre of what the stock ohm values are for the primary circuit and as the the dealer wants 100.00 u s dollars for a replacement i am looking to run 2- 1 ohm resistors in series and see if this will work
    I cant seem to locate the specs on it.
    I a have the clymer manual and cant find it any where. can any one give me ideas on nhow to fix this issue.
    should the machine still run anyway
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Eddie Lawson is God! BTK Expert elr658's Avatar
    Join Date
    Nov 2004
    Location
    Seymour,CT
    Posts
    5,376
    Ballast resistor? New one to me.
    Describe the problem, I'll try to help. That bike needs to stay on the road.
  4. #3
    Guitar nerd BTK Expert cudaosix's Avatar
    Join Date
    Apr 2005
    Location
    Miami, Florida
    Posts
    3,542
    I'll guess the resistor your talking about is the one that works with the coils on the early elec. ignition? If so, what I did was swap the coils for two Dyna 3 ohm coils and bypassed the resistor.
    Over 40 MegaFonzies and rising
    1980 KZ1000
  5. #4
    Obsessed by Z1's BTK Expert Jeff.saunders's Avatar
    Join Date
    May 2005
    Location
    Upstate NY
    Posts
    515
    Under the tank is a 1.5 ohm ballast resistor on these bikes (approximately 6" x 1" x 1"). It allowed Kawasaki to use low resistance coils (around 1.5 ohm).
    Usually these are easy to find as many folks remove them when replacing the coils with 3 ohm coils
    jeff@z1enterprises.com turbo'd Z1, stock Z1, stock Z1A, GS1000 (2)
    www.z1enterprises.com
  6. #5
    Join Date
    Sep 2006
    Posts
    56
    I Found a 2 ohm 20 watt power resistor at a local electronics shop.
    and i adapted it to fit.and repaired the off switch and The fix works, but i wonder if the .5 ohm difference will be an issue,next i will put the carbs and tank and all the windjammer back on and see how it turns out i havent gone two years without riding this machine since i have had it and i am feeling a little impatient. i will try to upgrade to better components when i can set aside the money. getting it to work at stock will have to do for now
    I appreciate all the advice and will reply when time permits,kids family work and school etc.
  7. #6
    Join Date
    Sep 2006
    Posts
    56
    tested the 2 ohm conv and it works will work on other issues later in week thanks for all help
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 1983 KZ1100 L shaft drive speedometer
    By jat307 in forum Vintage Motorcyle Info
    Last Post: 04-10-2013, 08:10 PM
  2. shaft drive On Vulcan 750??
    By Conan Obrien in forum Kawasaki Cruisers
    Last Post: 10-22-2006, 08:24 PM
  3. Kz LTD 1000 and Kz 1000 1977
    By Dan1977 LTD in forum Want to show off your ride?
    Last Post: 03-11-2006, 11:33 PM
  4. Balance Shaft timing
    By IFixAircraft in forum The Mechanics Corner
    Last Post: 04-18-2005, 06:30 PM
  5. 1980 KZ 1000 Carbs, Help?
    By Cisco47E in forum The Mechanics Corner
    Last Post: 07-16-2004, 11:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
