Oil leaking all over the heads
+ Reply to Thread
Results 1 to 4 of 4
Thread: Oil leaking all over the heads
  1. #1
    Foil Inspector BTK Beginner
    Join Date
    Nov 2004
    Posts
    116
    Default Oil leaking all over the heads
    2 questions, my KZ1100 is leaking from the heads, badly...like I cant wear any decent pants. So, one of the issues is stripped bolts one on the valve cover, at least on on the head...one of the smaller ones... Any one had any experience with retapping heads??
    Question 2. I replaced the stator last year and it didnt have a gromet. Turns out you cant replacement ones from Kawa, because they were part of the stator... anyone know of any aftermarket sources? or any way to homemake one? Its a big hole to fill and my toes are getting oilly, it also leaves quite a puddle if I dont put it on the center stand!
    Thanks!
    jono82spectre
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Another old fart Old Walt's Avatar
    Join Date
    May 2006
    Location
    Ohio
    Posts
    38
    Timeserts or heli-coils for the stripped threads. Try Jeff Saunders at Z1 Enterprises for a grommet fix.
    1982 750GPz
  4. #3
    Burt Munro Is My Hero BTK Expert 78_KZ750_Cafe's Avatar
    Join Date
    Jul 2005
    Location
    Ferndale, MI
    Posts
    665
    wait, are the bolt heads stripped or are the bolt holes stripped? if the heads are stripped go get a set of easy outs (or whatever they're called) from craftsman, they'll come out no problem. As far as grommets go, if its a round one you can pick up generic grommets in a variety of sizes at a hardware store. If it's an odd shape you may be able to use a silicone based sealant with a hardener to close the hole off.
  5. #4
    Join Date
    Nov 2004
    Posts
    116
    Its the head bolt holes,
    I tried to fashion a grommet and then used silicone form a gasket, still leaking, will try Jeff, thanks!
    j
    jono82spectre
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. men's rules for women - wouldn't let the wife see
    By Freakinout in forum Off Topic
    Last Post: 09-29-2010, 03:08 PM
  2. in the mail - Vulcan 2000 Oil Level Check Procedure
    By Spok in forum Kawasaki Cruisers
    Last Post: 11-05-2008, 11:19 AM
  3. Beware of auto oil and additives
    By JK591 in forum Kawasaki Cruisers
    Last Post: 04-03-2008, 12:32 AM
  4. Oil leak at heads
    By bjones in forum Kawasaki Cruisers
    Last Post: 07-06-2005, 03:44 PM
  5. Kawasaki Vulcan leaking oil after oil change
    By J-Alan in forum Kawasaki Cruisers
    Last Post: 09-15-2004, 04:36 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
