Fuel Leak
+ Reply to Thread
Results 1 to 8 of 8
Thread: Fuel Leak
  1. #1
    Canajen eh? BTK Intermediate jharold's Avatar
    Join Date
    Jul 2006
    Location
    Nova Scotia - Canada
    Posts
    135
    Default Fuel Leak
    My 1984 KZ750L has a fuel leak in the petcock assembly. There is a white plastic gasket between the reserve/on switch and the bowl. The pic shows where there is a groove running between the gasket and the plastic.
    I took it apart this morning and cleaned it but it still sprays fuel out of that groove when the bike is running. Does anyone know what would cause this?
    Any help would be appreciated - Thanks
    Jeff
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    bustedfeet BTK Expert
    Join Date
    Jun 2006
    Posts
    2,661
  4. #3
    Join Date
    Jul 2006
    Location
    Posts
    135
    Cool thanks for your help. I'll order a kit today.
  5. #4
    Join Date
    Jun 2006
    Posts
    2,661
  6. #5
    Join Date
    Mar 2007
    Posts
    4
    Default Fuel leak from petcock diaphragm groove, EX-500
    I have an 1995 EX-500 with this exact same fuel leak coming from groove on the petcock diaphragm. (Great picture below.) I'll try the petcock rebuild kit, but why was the diaphragm designed with this groove? To flow gasoline in case of a leak? Or to intake air? Thanks.
  7. #6
    KZ Kool! Forum Supporter Nate's Avatar
    Join Date
    Oct 2004
    Location
    Marysville, KS
    Posts
    2,818
    With the two diaphragm design, there has to be some way to allow the spring and atmospheric pressure to close the fuel valve. It also acts as a relief between the two diaphragms.
    "Riding is the reward for time spent wrenching."
    "Wrenching is the result of time spent riding!"
    KZ650
  8. #7
    Join Date
    Jul 2006
    Location
    Posts
    135
    I installed a new kit and it seemed to fix the problem.
  9. #8
    Join Date
    Mar 2007
    Posts
    4
    I second that. I had a fuel leak coming from the groove on the petcock diaphragm. (EX500 Ninja.) Exactly as shown in the photos above. Replace the $12 petcock and you're done. Problem solved thanks to this post.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Fuel leak ... 2000 ZX7R
    By jmesserer in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 09-11-2006, 05:55 PM
  2. OK I Give up! What Is SeaFoam?
    By msa1956 in forum Kawasaki Cruisers
    Last Post: 07-22-2006, 12:46 PM
  3. Oil or Fuel Leak
    By Aussie1 in forum Kawasaki Cruisers
    Last Post: 01-31-2005, 09:16 AM
  4. EX500 Fuel leak
    By liquidordinary in forum The Mechanics Corner
    Last Post: 03-23-2004, 03:40 PM
  5. Fuel Leak from unknown valve...
    By ZNZoomiN in forum Kawasaki Cruisers
    Last Post: 02-15-2004, 08:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
