KZ Owners
+ Reply to Thread
Page 22 of 43 FirstFirst ... 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 ... LastLast
Results 421 to 440 of 858
Like Tree1Likes
Thread: KZ Owners
  1. #421
    Flying Squirrel BTK Beginner Bad Kaw's Avatar
    Join Date
    Jan 2008
    Location
    Kansas
    Posts
    111
    Quote Originally Posted by kzbatbike View Post
    I got my faring from Moto Tumbi, in Australia
    kzbatbike,
    Hey, did you get the 'Cotton Telstar' upper fairing? How much was it? Thanks,
    -KR
    ’82 KZ 1000 J
    ’82 KZ 1000 J: ELR Clone
    ’82 KZ 750 R1 (GPz)
    ’78 KZ 1000 D
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #422
    Turtle Wax Taster BTK Intermediate
    Join Date
    Sep 2006
    Posts
    162
    This George Wired guy charges a fortune to do a simple carb rebuild. Just take the carbs apart yourself and soak the carb bodies in carb dip. Replace the O-rings and gaskets. Done.
  4. #423
    Join Date
    Sep 2006
    Posts
    162
    Quote Originally Posted by Russ Jackson View Post
    Max, Very good looking clean bike. I always liked the look of that tank.
    Here are some pictures of the Bike and Carbs. Thanks Again...Russ
    Looks like VM29's to me. That orange sealer is because the drain plug o-rings are shot. I recently went though some VM29's and assembled an O-ring kit by purchasing in bulk from McMaster-Carr. Have tons of spares so contact me if you need any. http://www.kawasakimotorcycle.org/fo...e-o-rings.html
  5. #424
    Finally Got Into First Gear BTK Beginner
    Join Date
    Dec 2008
    Location
    Ohio
    Posts
    51
    Actually the previous owner glued some plastic plugs in with some red goop. I sent you a message regarding the O rings etc. Thank you...Russ
  6. #425
    Join Date
    Dec 2008
    Location
    texas
    Posts
    5
    hey man do you have any idea where to get the cover for the air filter for a 1982 kawaski kz 440 ltd belt drive? or how to make one? Im afraid this is messing with the bike making it run to lean.
  7. #426
    Semper Fi precise86's Avatar
    Join Date
    Oct 2008
    Location
    Augusta, Ga
    Posts
    38
    Quote Originally Posted by kelly_canales20 View Post
    Here is a list of what ur looking for, all in the search. But as a fellow 440 owner I got it for you. Good luck
    http://www.kawasakimotorcycle.org/fo...archid=1893164
    Riding during ur lunch hour is like gettin a "quickie" during ur nooner~"Me"
  8. #427
    Join Date
    Dec 2008
    Location
    texas
    Posts
    5
    Sorry I tried clicking on the hypertextlink with no success. This is your 440 an 82?
  9. #428
    Join Date
    Oct 2008
    Location
    Augusta, Ga
    Posts
    38
    yes it is, a belt drive. still has the original airbox/filter. Just goto the top to "search" and type in keyword "440 airbox"
  10. #429
    Refrigerator Magnet Test Engineer BTK Expert cmdrstp's Avatar
    Join Date
    Oct 2008
    Location
    New York
    Posts
    474
    Attachment 25284
    KZ440LTD A2...my first and only.
    I never saw a wild thing sorry for itself.
  11. #430
    Join Date
    Nov 2008
    Location
    Milwaukee, WI area
    Posts
    26
    Default Original owner
    Metalesp, you'r correct. There are a lot of us KZ owners out here. Here in Wisconsin, mine's put up 'till spring. Thirtyinches of snow not good for Sunday riding.
    My steed is one of the "touring' packaged" ones of 1978. Not many of these still equipped as most owners removed those related items for a more naked bike look, or the items got damaged in spills.
    Many more years of happy riding to you all and a safe 2009 to everyone.
    Scootermon
    '78 KZ650 'Touring Pkg'
    Original owner
  12. #431
    Join Date
    Dec 2008
    Location
    Ohio
    Posts
    51
    Quote Originally Posted by Scootermon View Post
    Do you have any pictures you could post?...Russ
  13. #432
    Clutch Cadet BTK Expert Skunkwurcx's Avatar
    Join Date
    Apr 2007
    Location
    Eastern Passage, Nova Scotia, Canada
    Posts
    353
    It looks like your 81 has the same mags only with disc brakes instead of the old drum style. Are they interchangeable?...Russ
    Heya Russ....nice bike you found there. Definitely keep the smoothbores. As for the wheels, they look to me like teh Morris wheels that were an aftermarket alternative for our bikes back then. I'd keep them on it for sure. If you want better braking there are/were dual frt disc kits available for our bikes, of which mine is equiped.
    1977 KZ1000 LTD now Z1000A
    2007 Vulcan 900 Custom(Sold)
    2002 ZX9R
    2002 ZRX1200-R
  14. #433
    Join Date
    Nov 2008
    Posts
    5
    have an 81 650csr
  15. #434
    Join Date
    Dec 2008
    Location
    Ohio
    Posts
    51
    Well three weeks later and a couple hundred dollars in parts and it runs great. I cant say enough about the poeple at Z1 enterprizes. They are really professionals. Changed the coils, replaced some parts, gaskets and O-rings in the carbs. And cleaned them out. The best product I found for cleaning the carbs out was Berkbile instant Gum Cutter in a spray can. It took off old gas varnish immediately. Amazing product.
    Question for the pros out there:
    It has a miss at about 4000 rpm that works itself out at 5000. I am also using individual air filters on each carb as opposed to a box. With the adjuster on the carbs backed all the way out it idles at 1400 and will not go lower. Any ideas as to the miss? The miss only takes place when riding...Russ
    Once again thanks to all of you on ths site for the help.
  16. #435
    KZ Addicted (needs Help) BTK Expert Andy the gringo's Avatar
    Join Date
    Apr 2006
    Location
    Akron, Ohio
    Posts
    498
    I'll tell you what Russ, I don't know what you had to give for your bike but it's a gold mine in "period correct" goodies. Those are Lester mags and they are pretty sought after. Those smoothbores fetch huge money when they come up for sale on ebay as do the Kerker headers. I doubt you can get hurt on that bike money wise.
    80 Z-1 Classic
    84 GPZ1100
    77&79 1000 LTD
    76 KZ900
    KZ750 X 2
    KZ650 X 7
    KZ550 X3
    305 CSR
  17. #436
    Riding every day! BTK Expert OKC_Kent's Avatar
    Join Date
    Sep 2005
    Location
    Oklahoma City
    Posts
    1,063
    Check your throttle cable adjustment, if that's not it then I would try to remove the carbs and bench synch them. The slides may be too high and need to be lowered.
    Oklahoma City
    '78 KZ 650
    '83 KZ 750
    Proud Marine Corp Dad
  18. #437
    Join Date
    Dec 2008
    Location
    Ohio
    Posts
    51
    Quote Originally Posted by Andy the gringo View Post
    I have almost nothing in the bike. Less than $600 so far including the bike. I have an office up in Streetsboro Ohio so I get up there all the time. In the spring I will drive it up and maybe we can meet for lunch.
    OKC I think you are right about the slides being up too far. That would account for the high reving when the choke is applied.
    Does a low Z1F number have anything to do with value?
    ...Russ
  19. #438
    Made It To Second Gear BTK Beginner EthanKZ750's Avatar
    Join Date
    Jan 2009
    Location
    Louisiana
    Posts
    85
    i recently bought 79 kz750, heres a link to a video i made of it:
    YouTube - My New 1979 KZ750 B4
  20. #439
    Join Date
    Dec 2008
    Location
    Ohio
    Posts
    51
    Update on progress:
    Put a quick coat of paint on the spare tank, covers and tail. Then cleaned it up a little. Got the carbs syncrinized and it is running very well. Been too cold to really go for a long ride since I got it running right. Today is -10 degrees maybe next Tuesday when it hits +33. Here is a couple of pics. Thanks again all...Russ
    Haven't decided on a seat yet.
  21. #440
    Join Date
    Jan 2008
    Location
    Kansas
    Posts
    111
    Russ, the bike is looking very good.
    Two questions: do the carbs tilt down a bit? ...and are those Lesters?
    -KR
    ’82 KZ 1000 J
    ’82 KZ 750 R1 (GPz)
    ’78 KZ 1000 D
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Attention 90-96 Vulcan 500 (en500) owners!
    By windwsxpbronco2 in forum Kawasaki Cruisers
    Last Post: 05-24-2011, 01:49 PM
  2. Owners Manuals?
    By storm16 in forum Main Lobby
    Last Post: 06-25-2006, 01:50 AM
  3. Meet the Owners of Beartooth Kawasaki
    By 2WheelFun in forum Main Lobby
    Last Post: 10-20-2005, 09:36 PM
  4. Replies: 7
    Last Post: 09-11-2005, 11:19 AM
  5. Good time owners club
    By Oldmanbiker in forum FAQ'S
    Last Post: 12-05-2004, 01:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
