hi, new to forum.
I have a 81 KZ1000 LTD. couple days ago the vacuum fuel tap started to leak. I took it apart and the diaphragm is torn, and was leaking between the diaphragm and the nylon spacer that separates the 2 diaphragms. Well I went to order a rebuild kit and it does not look like they make one for this fuel tap. I ordered one that was close hoping it would work, but it did not.
question is, is there any other fuel taps that can swap on there? this one is held on my 2 6mm bolts, and has the oval filter that extends into the tank. Other option I was thinking about is a new tank, but there is nothing on ebay, except for police tanks. Will a police tank work? it has the fuel sender, does it mount the same? does it hold more (that would be nice).
Thanks
Scott
LinkBack URL
About LinkBacks
