LinkBack | Thread Tools |
ok a short time ago i grabbed a goodie from a bike boneyard ..whats it worth?
i got a pretty much complete f81m engine still std{and good} bore . no number on the case {maybe over the counter or warrenty cases} bike was left out since dunno the plastic tank is fungus .. seat went south .. only major prob wire was off the mag coil to points. no kick starter or shifter , and the float was robbed from the carb .. but eaven the airbox boot was there intact.. i have a set of yamaha 68 mm rings wich should be the same and a spare f11 some kid took apart and destroyed .. i know the motor bolts are in different places but i have a mig welder ... that was i was thinking about doing that or sell it on ebay .. i have another complete f11 here i needed a 40over keystone ring set,both f11's are 040 wiseco.. wich that parts f11 had good upper ring bad lower {kids} a good jug use my piston..now i need to splurge and get a set of 69mm rings and use just one .. jug's quick ported , i am finish filing it by hand to make some more noise around here.i like making noize {noize rulez} i have one of those neighbors.. he dont like noize .. i dont like him . i think my noize eavens it out. fyi what for rings do i need? they seam to be the same size as stock yamaha 81 to like 88 yz 250 triz 250 and 82 it 250 :: what newer kawasaki's use the same 68mm rings ? |
Slow Guy on a Fast Bike
I'm afraid this member hasn't posted here since June. Hopefully he still keeps an eye on the forum and will respond.
Failing that you could try to send him a private message, and he may get a notification on his email. Best of luck.
08 Midnite Sapphire Blue ZX-14 |
