Old 04-04-2007   #1 (permalink)
Bigphil001
Default 1980 Kz750LTD carb rebuil question
Please excuse my newbieness , I took the carbs off, and I noticed that when the choke is pulled down, it pushed the slide, or as my repair manual calls it the throttle valve down, on only two of the cylinders, On the slides I noticed that there was a notch on them, that appears to be made to clear the choke butterflies. Two of the cylinders have the notch facing the choke butterflies, so the slides clear it and they do not move when the choke is on. The other two, do not have the notch facing the choke butterflies so when the choke is on it pushes the slide up on those two cylinders. Is this correct? it doesnt seem to me like it would be correct. Also where is a good place to buy rebuild kits. THis is the place that I was planning on buying them from.http://www.oldbikebarn.com/motorcycl...php?bike=KZ750
Also any tips when rebuilding them would be much appreciated
Thanks for the help!
Bigphil001 is offline   Reply With Quote
Old 04-29-2007   #2 (permalink)
Roofgunner
Turtle Wax Taster
Without seeing the carbs this is difficult. All cyl. should be choked the same. Is there any reason to believe that someone tampered with the carbs? I used to work on these but, it's been along time ago----1980. Wish you had photos but the manual should be of help. Sorry.
Roofgunner is offline   Reply With Quote
Old 04-29-2007   #3 (permalink)
peterc
peterc
go to members list look up wiredgeorge he rebuilds carbs and you can go to his website from there.
peterc is offline   Reply With Quote
Old 04-30-2007   #4 (permalink)
Chevy
Reposting from your previous thread:
I'm not sure whether anyone is still watching this thread or not but... I just checked the spare rack of carbs I bought for my 1982 KZ750 Spectre and the slides should NOT be hit by the choke butterflies. Each slide has a notch in it that keeps the butterflies from contacting them. I may be wrong but it sounds to me like the slides have been oriented incorrectly during a past rebuild. You might want to remove the top cap and make sure the rubber diaphram is facing the correct way. There should be a small "tab" which sticks out very slightly from the edge. This little "tab" should be facing the mixture screw that's on the throttle blade side of the carbs. I'm sorry I don't have any pictures to show you exactly what I'm talking about but things SHOULD be more clear once you take off the top cap and notice that the diaphram isn't completely round and neither is the groove the edge of the diaphram fits into. Best of luck!
Chevy is offline   Reply With Quote
Old 05-03-2007   #5 (permalink)
wiredgeorge
Vintage Motor Mechanic!
He has CV34 Keihin carbs. Two carbs on the side of the choke arm have the choke butterflies actuated directly. The other two (on the other side) are linked and the linking parts must be assembled correctly for the remote two butterlies to work with the directly actuated ones. Sounds like the slides are also not correctly oriented. If the tops are removed, you can see a groove that the slide diaphragm is set in and it must fit in the slot correctly to orient the slide position otherwise the slide cut out is not correctly oriented. Sounds like someone who didn't understand what they were doing disassembled/reassembled the set you bought.
wiredgeorge
Mico, TX
wiredgeorge is offline   Reply With Quote
GPX750R - carb question? qzak Vintage Motorcyle Info 10 04-09-2008 04:43 AM
1980 KZ250 Ltd Carb probs jomama Vintage Motorcyle Info 1 09-28-2006 03:41 PM
Need A Carb For A 1980 Kz250 macfl Vintage Motorcyle Info 0 08-30-2006 05:08 PM
'89 Ninja 750 Carb Question Glaxtx Kawasaki Streetbikes/Sportbikes 3 06-29-2006 02:16 PM
Newbie question re 2004 Classic Carb versus 03/05 Classic FI scharfg Kawasaki Cruisers 14 11-22-2004 09:15 PM
