#21 (permalink) |
I definately dont want to wait till redline for my fan to kick on, so manual fan switch it is. Ive got another question. I just purchased a yoshi R&D full exhaust 4into1 system and i was wondering how big to go up on each main jet, ive also got no filter but soon to be k&N. I know on my atv when a got a filter and pipe i went up 4 sizes on my main jet but i didnt know if that would be the same for the ninja or not, i dont really want to buy a whole jet kit, just individual ones there alot cheaper.
#22 (permalink) |
Sit speling cheker
Now you've gone and done it.
Your bike is probably never going to work properly unless you devote the time and money to tune it correctly. Just bumping up your main jets likely ain't gonna cut it and buying an entire jet kit is not a magic bullet either. The mains work from half to full throttle. Getting it to work off the bottom to mid is probably going to take pilot jets and new jet needles or you're going to end up with less than great performance. As a new rider on a new bike, low to medium speed throttle response is going to be very important on how fun, safe, predictible and smooth you can be. These old bikes are slowpokes compared to modern iron but they'll still yank your arms off if ridden hard and they have a lot of torque. Having it carbuerate correctly throughout the entire rev range is going to be very important to you once you start riding it. Sorry to not be more positive but it you have the stock pipes and airbox/filter, get it running this way first then do your mods. It will be easier if you know where you are starting from rather than tossing on a pipe & K&N and guessing.
...Diane '85 ZX900A2 Ninja(modern classic) Mayor & Chief Sanitation Engineer - DooberVille |
#23 (permalink) |
I cant help it
#24 (permalink) | |
I drilled my pilot jets to .040 mm, set the air screws to 2 3/4 turns out from seated, removed the shim I found under each needle and the bike runs perfectly. 4-1 Vance & Hines pipe with a cotton factory filter. I can tell you that going to pods is going to make tuning a bit harder, but it can be done. I did pods on my KZ550. Also drilled those pilots to .040 mm and it runs like a champ. |
#25 (permalink) |
Uncle Bob's Love Child
My bike has pods on it and I HATE them with a passion. Any turbulence or strong side wind makes the bike run like crap (screws with the air/fuel mixture).....and Ive heard whatever you do DONT get them wet.
So if its windy I have to suck my legs in hard against the filters to make the bike run right. Big pain in the ***.......but maybe the filters on your bike are in a better spot. |
#26 (permalink) | |
Sounds like you need to make yourself a little airbox for the pods. Is there a reason you havn't gone back to the stock box because you hate the pods so much? |
#27 (permalink) |
yes they do run hot,the best design switch and easy pics to follow is on the gpz zone,ive wired a swich into mine exactly as shown in pix and it works fine and the standard wiring is retained as well so if you forget to switch fan on it will still come on automatically when its almost too late,mine started leakinfg oil out the relief hole on the pump,i put new bearings and a seal in it,fixed oil leak but created a water leak,need a waterpump now if anyones got one?
#28 (permalink) |
Custom User Title
Great Bike!! I had an 85 as well. For the record that bike would overheat at the hint of a traffic jam. I had the toggle fan too.
One of the first things I had to do was stiffen up the mirror springs so they wouldn't fold in when going 180+. Yeah it was a Great bike.... |
#29 (permalink) | |
Ive seen a few pod boxes and if I cant find a stock box at a fair price I may try making one. |
| Ways to drop your motorcycle | Freakinout | Main Lobby | 143 | 5 Days Ago 04:16 AM |
| Good Step Up Bike From EX 500 Ninja? | Necromancer | Kawasaki Streetbikes/Sportbikes | 23 | 05-13-2007 06:55 PM |
| I just bought this bike, some problems (93 ninja) | solimines | Kawasaki Streetbikes/Sportbikes | 7 | 11-05-2006 07:05 AM |
| FS: 2003 Ninja EX250 in Delaware (starter bike) | larryd | Streetbikes Buy/Sell/Trade | 8 | 11-23-2005 04:25 PM |
| Looking for bike cover for 04 ninja 500 | 500r | Kawasaki Streetbikes/Sportbikes | 5 | 01-26-2005 07:47 AM |
