#22 (permalink) |
Lowridin' Minitrucker
Steering dampers are worth their weight in gold on these old bikes. I picked up an NHK damper for mine that has 7 different settings. I'll have to make a bracket to be welded on to the frame & purchase a 36mm fork clamp. This will greatly help against hard steering feedback in twisties and any type of speed wobble you may encounter. Of course, making sure you have well greased bearings and the fork oil changed will help alot too.
Jason Rymell '80 KZ750 LTD (H1): Cafe Racer / Sport Bike PA Kawi forum rides ROCK!! |
#23 (permalink) | |
AMA NRA LIBERTARIAN
![]() Join Date: Sep 2006
wheels because when you have spokes that is one more reason for your bike to wobble if they are not true. My KZ1000 had a little wobble because of the frame or bearings. Yours may have a bigger wobble because of the spokes. Or not. |
#24 (permalink) |
Back in 1973 I had a H2 750 triple and it had a high speed wobble on deceleration just as yours did, it almost put me on the ground several times, I did find out that the rear wheel had loose spokes every time, after tighten the spokes and retruing the wheel the wobble would go away till the spokes got loose again. Hope this all helps Jimsdad
#25 (permalink) |
It's all in the cc's
Hi there motorman224, glad to hear you are ok.
Man those wobbles are the pits! It's one of the reasons I steered away from street bikes in the early days. Nearly did myself in during a wobbly incident just on entry into a left hander on a mates Kwaka 900 back in the day. This was a a bike with 2 steering dampers! I think that my strength and clear thinking saved me, basically I don't panic under pressure, and I stayed focused on the matter at hand. I was lucky in so much that even though I ended up a 200mtrs off the road in the scrub, once the dust settled, I was upright with no damage to bike or rider. Back in those days, plenty of wobbling to be done on a dirt bike, on the dirt and out here, there is plenty of dirt. Ha, knobbies on the bitumen lets you know you are alive too! Controlling the wobbles. Don't hit the brakes when in a wobble, slowly apply power untill you can control it again. Slowly apply brakes or use the gears to slow down to a speed where you are back it control. These wobbles can happen to all types of vehicles when towing a trailer. The same control principles apply. I know that accelerating doesn't sound like the right thing to do BUT it is. I'd also do like the other posts mention checking, spokes, bearings, tyre pressures etc.
ThumpinKwaka v1.0 = 2006 Vulcan VN2000 LT Classic ThumpinKwaka v2.0 = 2008 1400 GTR FarRider #43 |
#27 (permalink) |
Mine is a 1980 LTD1000. Did the same thing yours did when I first bought it. Except I had an old Honda 750 before that would do the same thing and I already knew how to make it stop. As others have mentioned, get back on the throttle a little, but also not mentioned is, it helped me to rear back as hard as I could on the bars, then slow down gradually. Next time you'll know what to do. In the mean time, you'd be surprised what a brand knew set of tires will do for the old girl, (provided all the other stuff is up to par, swingarm and neck bearings, fork oil, etc). I put some new Bridgstones on mine and now she no wobble. I have no idea how fast I'm going, speedo only goes up to 80, but in fifth gear at 8000rpm, she no wobble at all.
Yep, new tires, new underwear, you'll be good to go. |
#28 (permalink) | |||
Third Gear And Gaining
If you're zipping in and out of lanes around traffic, you're asking for a hurting. If it's a clear road and/or traffic is running as fast as you are, I don't see a problem. Speed limits on highways are artificially low. Keep in mind, you said "speed and carelessness", it's not the first part, it's the second part that's the issue. Speed just compounds carelessness. Quote:
My speedo only goes to 85, but I have to figure in the 8% under for my speedo, so 85 is actually 92. Although I only checked the speed accuracy at 55 (on the speedo, actually 60), so who knows what it is at 85. Or is it 92?
MechLogs.com Free vehicle maintenance logging and reminders. |
#29 (permalink) |
Navy Vet S.A.R. crew
I've always used my tach to estimate my speed above 85 where the speedo pegs. Mine works out to 16mph for every 1k rpm in 5th gear. I've had some newer bikes clock me with their fancy digital speedos and it turns out my system is pretty accurate if theirs is right.
#30 (permalink) |
I had a local cop check mine with his radar. Dead on at 50mph. And when I get to around 80 just before its pegged, the needle bounces all over. Plus at that speed and above, I'm too busy looking as far down the road as I can. Half a second of looking down to the gauge just to appease my curiosity costs me quite a bit of reaction distance. I thought about putting on a 160mph speedo, but then I thought, what's the point?
#31 (permalink) | |
I agree, at 160mph, a speedometer is too much of a distraction. Speaking of speedometers, has anyone tried retrofitting an older bike (originally a mechanical speedo) with one of those new fangled LCD ones? Mostly a curiosity if it has been done, not so much wanting to do it myself.
#32 (permalink) | |
Obsessed by Z1's
With an old bike there are a VERY long list of things contributing to problems like this. The following list is not in any particular order:
#35 (permalink) |
Motorcycling's Dr. House
Jeff Saunders is the voice of reason.
I have NEVER EVER NEEDED a steering damper. AND I have been 165 MPH on a Z. (caveat, I ALSO fixed everything that could cause a tank slapper. Incidentally, I also know how to ride which seems to be a disappearing talent) |
#36 (permalink) | |
Banned
Isn't it a sin to go that fast on an old bike? LOL Shame on you, you should be puttering around at 50 mph on these on things, you know they weren't built to go that fast. ![]() |
#37 (permalink) | |
btob
![]() Join Date: Jan 2007
+1. Agreed. |
#38 (permalink) |
I think I'll put bags on a ZX14 and go after the world's fastest bagger. Klock went 147 on his HD with a zillion bucks worth of mods. All I'd have to do is make sure I have gas.
Maybe resurrect the museum piece. |
#39 (permalink) |
I have a '79 KZ1000 LTD, had a little wobble at around 100mph when I first got it. I dropped the front forks about an inch, put on handlebars that were a lot straighter ( 4 inch I think as opposed to the old hangars ). Since then the bike is like a tank at high speeds, not even the slightest hint of wobble. Much nicer to drive at any speed really.
#40 (permalink) | |
btob
