New to the board, '83 GPz1100
+ Reply to Thread
Results 1 to 16 of 16
Thread: New to the board, '83 GPz1100
  1. #1
    Join Date
    Sep 2007
    Posts
    18
    Default New to the board, '83 GPz1100
    Hey guys, another newbie here. Sorry to say! I'll probably be asking a lot of stupid questions, so bear with me.
    I just picked up an '83 GPz1100 with EFI. The odometer shows 2860 miles, thats right, less than 3k. This thing still has the original tires on it. The tag on the plate says it was last registered in '96. Soo.... anyway, I bought it from a kid who's stepdad bought it at an estate sale as it is right now, so he really knows nothing.
    I brought it home (it looks like it might have spent some time outdoors) and started assessing the bike. The exhaust was off, the throttle bodies were set back, the valve cover had been just laying on the head. The bike came with a box 'o parts, which included a new head gasket... hmm... someone was taking the head off. Did a compression check-
    90,90,120,60. Not good. I took the head off tonight and found that I can see light through a couple valves and one port has some significant rust. Obviously some of the valves are stuck. The crosshatch can still be seen in the cylinders, so I filled them with oil to see how bad the rings are and if they're stuck.
    So I'll be asking questions about this bike. I know its old, but its still pretty cool. I'll try to post in appropriate sections.
    Thanks guys!
    Chuck
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Vintage bike addict BTK Expert antiq's Avatar
    Join Date
    Aug 2007
    Location
    I live in eastern ohio
    Posts
    4,809
    Sounds like a cool project bike. I hope fixing the valves will be all that's needed to get full compression. With only 2800 miles the rings should be fine. Keep us up on how it's going. I'm still fixing on my 82 750 ltd.
  4. #3
    Z Cruiser BTK Intermediate orangeRcode's Avatar
    Join Date
    Sep 2007
    Location
    Mustang/Yukon, OK
    Posts
    124
    Welcome to the boards. I am working on a 75 Z bike which had set for 10+ years.
  5. #4
    Top Gear Full Throttle BTK Expert ratvespa's Avatar
    Join Date
    Feb 2007
    Location
    Las Vegas NV
    Posts
    303
    cool, another early gpz'er
    you could probaly get a gasket git for under 100, then rent a valve spring compressor and lap the valves with some valve lapping compound, clean it all up and slap it back together.
  6. #5
    Vintage Motor Mechanic! BTK Expert
    Join Date
    Oct 2004
    Posts
    507
    I wouldn't take the compression readings too seriously if you didn't hold the throttle open while doing the check. The readings will be badly off. I don't even check compression on an older bike until I let the rings free up. I generally use Yamaha Ring Free and pour it down the plug holes; let it sit overnight, then check. Compression will be pretty good since the oil itself will seal the pistons in the bores... so don't get too excited about your compression self-healing at this point. I would also pay attention to the cam chain timing if the valve cover was off... can't tell why and if someone had adjusted the valves and gotten cam timing wrong, I would ensure it was right before attempting to start the bike or even do the compression test as valves bend easily.
    wiredgeorge
    Texas Hill Country
  7. #6
    Navy Vet Search & Rescue BTK Expert StarGate's Avatar
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,890
    With that low mileage you would think the only damage is what has been caused by rust and lack of use. Should be able to get it going fairly easy if that rust didn't get to the cylinders and rings. Best of luck with it and welcome to the forum. OH!!!! Almost forgot to say, Pics Pics we like Pics.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  8. #7
    Join Date
    Sep 2007
    Posts
    18
    Default Part 2
    Pics? Can I post pics here? Remember, I'm new and havent really posted much, in fact, this is my first thread.
    I understand what you're saying George.. I was going to let some seafoam sit in the cylinders for a while as well, considering I'm planning on changing oil twice once I get her going. I poured some 5-30 motor oil into the cylinders last night and the two outside holes are the only ones that leaked. Only about a cm down over 24 hrs. Not too Godawful terrible IMHO.
    I was looking for a valve spring compressor at work today and the only ones we have are the old school ones, ones that wont do anything but raised springs.
    I'm taking the head to a local bike shop thats done work for me before on my Magna and have him quickie clean it up, just like Ratvespa said.
    Oh well, take care all!
    Chuck
  9. #8
    Join Date
    Apr 2007
    Location
    NE Arkansas
    Posts
    7,890
    Yes you can post pics in your thread. There are 3 methods.
    1. Open an account on photobucket.com or other hosting site and copy/paste the img link using the "insert image" icon that is located at the top of the screen when you are typing a response. (looks like a little landscape picture)
    2. Click the little paperclip icon at the top then upload your picture to the site.
    You have limited space for uploads so you would be better off to use method 1 for posting pictures.
    3. Click the "Insert link" icon and insert the link address to the pics.
    I always delete the default "http://" that comes up in the url slot before I paste my address or else I get double http://http://xxxxxx.xxxxx and it doesn't work.
    P.S. I made my valve spring compressor with an old C clamp and deepwell socket. Works great and it was old stuff I had laying around.
    Mike
    Original Owner
    1981 KZ1000-K1 LTD
    Bike Photos
  10. #9
    Red is Faster Forum Supporter Gpz1100's Avatar
    Join Date
    Apr 2005
    Location
    Lone Star State
    Posts
    1,236
    Thank God you're here now.
    I wuz begining to feel like a redhead step-child.
    PM me if ya need parts.
  11. #10
    Forum Supporter Forum Supporter gpzrider's Avatar
    Join Date
    Jan 2005
    Location
    Southern Indiana
    Posts
    2,267
    Welcome aboard. Sounds like a great little project. Can't wait to see some pics.
    1998 Honda CBR1100XX,
    1991 Kawasaki KE100
    1987 Honda Rebel 250
  12. #11
    Join Date
    Sep 2007
    Posts
    18
    Nothing to see really.. its pretty stripped down now, obviously the head is off.. I'll take some pics this weekend and put em up on my putfile folder..
    '83 GPZ1100 - work in progess
    '83 Honda V65 Magna - gone but not forgotten
    South Elgin, Illinois
  13. #12
    Join Date
    Apr 2005
    Location
    Lone Star State
    Posts
    1,236
    Hey Chuck where you from?
  14. #13
    Join Date
    Sep 2007
    Posts
    18
    Illinois, land of Corrupt Democrats and some really cool Ghettos!!
    Seriously, about 35 miles west of Chicago, you're from Texas, no?
  15. #14
    Flying Squirrel BTK Beginner Bad Kaw's Avatar
    Join Date
    Jan 2008
    Location
    Kansas
    Posts
    111
    [QUOTE=Wrencher;811554]Illinois, land of Corrupt Democrats and some really cool Ghettos!!...QUOTE]
    Haaaaaaaaa! Hilarious...but true.
  16. #15
    Join Date
    Mar 2008
    Location
    Central IL
    Posts
    37
    Quote Originally Posted by Wrencher View Post
    No kidding? I'm just an hour straight south of Rockford. Down here in LaSalle.
    Hey, I have a mint set of 83 GPZ1100 exhaust pipes and the factory fuel injection set up minus the fuel pump for sale. It is also mint.
  17. #16
    Patriot Guardian Forum Supporter KyBoy's Avatar
    Join Date
    Feb 2006
    Posts
    817
    Welcome aboard!
    Good luck with the project bike. Keep us posted with your progress.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Motorcycle safety question for the board
    By Lattimer in forum Kawasaki Cruisers
    Last Post: 11-28-2007, 10:10 PM
  2. Need GPZ1100 Rear Wheel Info Please
    By inline4 in forum Vintage Motorcyle Info
    Last Post: 07-22-2006, 12:59 PM
  3. Floor board vibration
    By dutch11 in forum Kawasaki Cruisers
    Last Post: 04-25-2006, 11:55 AM
  4. New to the board...hello and first question
    By suprfly2k in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 07-25-2005, 10:36 AM
  5. service manual GPZ1100 '97 (zx1100f1)
    By woutergpz1100 in forum The Mechanics Corner
    Last Post: 07-10-2005, 11:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
