LinkBack | Thread Tools |
I have a 1976 KZ750 twin. It runs but it's pretty rough. I have the opportunity to buy a 650, including carbs and tranny, for $100. I have no idea what shape it's in, but I was thinking of getting the 650 and doing a complete rebuild and then sticking the 650 on my frame. Will it fit on the frame, and what kind of parts compatibility am I looking at? Are the trannies interchangeable?
My thinking is that I'd rather keep the bike operational so I can continue riding and learning, and then once I complete the engine rebuild I can switch it in so I have a nicely freshened up 4 cylinder. |
#7 (permalink) |
Sit speling cheker
This didn't just happen did it or is this another motor you have just sitting around? If this is a new CCV (Complete Crankcase Ventilation) hole, man, you have bad luck.
...Diane '85 ZX900A2 Ninja(modern classic) Mayor & Chief Sanitation Engineer - DooberVille |
#8 (permalink) | |
Banned
I was riding to work Friday, and knew immediately that I had lost a cylinder. Got it stopped, looked up front, and it was leaking oil from the hole. Then the oil started on fire! I tried to put the small fire out, but only managed to burn my hand on the exhaust. So I have a winter project, either that or I give up! |
#9 (permalink) |
Sit speling cheker
Oh man! Look for the bright spots...at least it didn't oil the back tire and put you down. Sorry for your misfortunes.
| To Engine Brake Or Not To Engine Brake, That Is The Question... | TMac | Kawasaki Cruisers | 50 | 04-16-2009 03:27 PM |
| Help with engine swap | dgo89kx250 | Kawasaki Motocross and Offroad | 1 | 06-25-2007 01:54 PM |
| 06 zzr600 engine swap | Narcosis | The Mechanics Corner | 1 | 06-07-2007 03:06 PM |
| ZX9R engine swap '98 to '00 | knuckleUp | The Mechanics Corner | 4 | 04-17-2007 10:40 PM |
| tec question on 99 ZX-6R engine | snake | The Mechanics Corner | 1 | 09-04-2004 12:46 PM |
