Old 10-16-2007   #1 (permalink)
spintop1
1967 C2SS Roadrunner
Default 1967 C2SS Roadrunner 120cc
Hello all
I'm a newbie to the forum.
I'm doing a restoration on a 1967 Roadrunner C2SS (120cc). It's in rough shape so if you have tips feel free.
One stumbling block I have already is the kawasaki.com site doesn't list an OS piston and rings, so I don't really know what to do there. I've taken the cyc block off and the piston and the cyclinder wall have some "cooking", so I do need to do something.
Does anyone know an expert that could help me determine if it's possible to use a piston and rings from another Kawi model (say from a KE125) as a replacement?
spintop1 is offline   Reply With Quote
Old 10-16-2007   #2 (permalink)
kawah1c
Way Too Much Free Time
kawah1c's Avatar
Just searched ebay. Found a set of 0020 rings for it. Keep your eyes open and I'm sure that you'll find a piston there as well. An ebay account is a must when you own an old Kawasaki.
Z1-R, H2, W650, H1C, F-11 ,G4TR ,KV75-A7 ,MT1,
KV80R-A, XL70-K1
kawah1c is offline   Reply With Quote
Old 10-16-2007   #3 (permalink)
spintop1
I did see those, so I went to the kawasaki site to get the part number for the OS piston but here wasn't a listing. If there's OS rings then there must be an OS piston right? So I guess, like you say, I just need to "keep my eyes open".
1967 C2SS resto in progress
Old 10-17-2007   #4 (permalink)
kawah1c
kawah1c's Avatar
There'e most likely 2 oversizes. 0020 and 0040.
KV80R-A, XL70-K1
Old 10-22-2007   #5 (permalink)
spintop1
Are there sources out there besides ebay I should be trying for an OS piston and rings? I've seen OS rings available for days now, but nothing on a piston on ebay, standard piston only.
Old 11-01-2007   #6 (permalink)
DawsonUSA
Finally Got Into First Gear
Sweet bike Love those!!
Dawson
DawsonUSA is offline   Reply With Quote
Old 11-08-2007   #7 (permalink)
spintop1
I got a line on some parts from Vintagekawasaki.com. They seem to be good folks there. Having said that, I haven't received any of the parts I've ordered yet. Wait and see.
Aside from that, has anyone seen a picture of a blue C2SS out there? The model I have is blue (actually more of a rust colour now), but the only pictures I've seen on the net are red and silver....no blue. If you got em, post em.
Old 11-09-2007   #8 (permalink)
hick
Restoring a 1968 C2SS
hick's Avatar
Send a message via MSN to hick
Here ya go!
http://img.photobucket.com/albums/v6...g?t=1194659981
hick is offline   Reply With Quote
Old 11-16-2007   #9 (permalink)
spintop1
I managed to source a .040 OS piston and some rings for the C2SS. So I'll be going to the machine shop to get a bore done next week. The Kawasaki Service Manual has some pretty good instruction for measuring the tolerances after boring and honing.
Are there any experts out there that have an opinion about other things I should be looking at? Say carb jets, or timing?
Hey Hick, anything in that shop manual of yours?
Old 11-17-2007   #10 (permalink)
kawah1c
kawah1c's Avatar
What's the bore now ? STD or 0020 ?
KV80R-A, XL70-K1
Old 11-17-2007   #11 (permalink)
raceman
need FCR carbs 4 ZX10 !
carb jets ? leave it stock,it shouldn`t need different jets. You`re adding a small amount of displacement with the overbore and at most you might raise the slide needle one notch and adjust the idle screw as normal.Your manual should specify timing and if not go off the marks on the mag.lf you`re at high altitude advance the timing 5 degrees over stock spec
raceman is offline   Reply With Quote
Old 11-19-2007   #12 (permalink)
spintop1
The current bore is standard.
Old 11-19-2007   #13 (permalink)
kawah1c
kawah1c's Avatar
I personally wouldn't skip a bore. The only exception would be if the cylinder was damaged and 2 O.S's was required to fix it. It's like going to bed being 39 and waking up being 50 years old
KV80R-A, XL70-K1
Old 11-19-2007   #14 (permalink)
spintop1
I probably could have gotten away with a 0.020 OS but the cylinder has some pretty deep grooves in it, so I figured I'd take the largest I could find. I tried taking a picture to show you but it doesn't do the grooves any justice.
Aside from having nowhere to go after a 0.040 OS bore, what other disadvantages are there?
Old 11-20-2007   #15 (permalink)
hick
hick's Avatar
I wouldn't worry about skipping an OS, as long as the machine shop doing it UNDERSTANDS you are skipping a size!
After all, it is not like you will be riding it enough to wear the overhaul out!
As for adjustments after the OS, I would not worry about them, either. The tiny amount of extra displacement should not require a change the settings.
Sometimes we tend to overthink a project. I know I am guilty!
So many bikes, so little time!
Old 11-20-2007   #16 (permalink)
kawah1c
kawah1c's Avatar
None Just make sure that you give it enough fuel running it in. You don't want to seize after half an hour on 2nd over. Better a tad rich than too lean.
KV80R-A, XL70-K1
Old 04-17-2008   #17 (permalink)
spintop1
Hey
I just got my bore back from the machine shop and the engine is ready to assemble.
I'm looking around for several parts. Ebay has some hits from time to time, but it's mostly junk. If anyone knows where I can pick up the following parts let me know:
muffler
front end complete
gear shift
chain cover
oil tank
side covers
Old 04-17-2008   #18 (permalink)
hick
hick's Avatar
You've got mail!
Old 4 Weeks Ago   #19 (permalink)
tscody42
i'm re-doing a 1968 c2ss and so far so good. i need to replace the kickstart shaft and it looks like i need to split the cases?? to do so. also i am having no luck w/ a chain gaurd for this old girl and think i may have to retro off another bike(any suggestions). shes running strong and was the first bike pops ever bought for me (bike was out of my life for 33 yrs when the old highschool sweetheart gave her back to me(bless her heart-she still looked good also-lol) cemoto
tscody42 is offline   Reply With Quote
Old 4 Weeks Ago   #20 (permalink)
herk
bustedfeet
herk's Avatar
ebbaayy search for C2SS chain guard: Kawasaki Roadrunner 120 c2ss c2tr Chain Cover Guard
I have no idea if that's the correct part for your bike. I'll guess that it isn't.
You could search there for C2SS, then ask the sellers if they've got the chain guard.
herk is offline   Reply With Quote
C2SS info please! VIN number location? Gus Elg Vintage Motorcyle Info 11 04-14-2009 02:40 AM
