LinkBack | Thread Tools |
Hello,
I have a 1982 KZ1000 LTD that I am removing the mag wheels from and putting about 1977 spoke wheels on in their place. The 82 LTD rotors are 6 bolt units that bolt directly to the mag rim, the 77 rotors are 4 bolt, but have a wider offset (measured from outside of the right rotor to outside of the left rotor) than the 82. The 77 rotors are not in great shape, and will require me moving my calipers out to make them line up properly. Do any of you know what rotors will bolt up to an early 4 bolt hub and the rotors line up with the 1982 calipers? My LTD 6 bolt rotors measure apx 5mm thick, 115mm outside left rotor to outside of the right rotor, and 270mm OD. My 1977 Hub measures about 68mm from the left rotor mounting surface to the right mounting surface, the 4 rotor mounting bolts measure about 78.5mm diagonaly from bolt center to bolt center (bolt circle) or 55.5mm from the center of adjacent bolt centers. So I think that the offset (base of rotor mount to top/outside surface of the disc) should be about 23.5mm Anyone know what rotors will bolt up and line up with my calipers on the 82? Thanks, Montie |
Hello,
Looks like have have partially solved the rotor issue. I went to Union Cycle Salvage in Houston, and found a 1981-2 KZ1000 CSR front rim with the rotors, the rotors bolt up to my early hubs, and I just need to find smaller bearings to fit the smaller axle on my 1982 vs the larger front axle on the 77. Then adapt my 82 speedo drive to the 77 hub. These things never seem to be as straight forward as they first appear. Montie |
#3 (permalink) | |
Red is Faster
![]() Join Date: Apr 2005
If it was easy, it wouldn't be fun. ![]()
Remember, it takes 43 muscles to frown, 17 muscles to smile but only 3 for proper trigger squeeze |
| 1977 KZdisc brake spoke rims on 1981KZ??? | FULLMONTIE | Vintage Motorcyle Info | 3 | 11-20-2007 09:15 PM |
| Bike-a-holics quick and easy brake bleeding guide | Spok | Projects and "How To" Write Ups | 6 | 03-02-2007 10:43 PM |
