First off I know I need new rotors all the way around, my bike still has it's origenal rotors by the look of them they are worn and grooved pretty bad. I had a shop check theme out and they said that in the valley of the grooves is thinner than the min thickness and the ridges are on or just a little thicker than min thickness... Does anyone know what rotors would work? I have the crossreferance program by zeddar and I have checked the buykawasaki web side, BUT they only give part number to part number referance, I doubt they would show what other rotors have the same bolt pattern, thickness, and overall diameter so you can see what rotors would work in what factor. I've seen some 1000 Concours rotors on e-bay which look like they would work with the bolt pattern and apparent overall diameter, same goes with some 81-82 kz1000 or ltd front rotors I've been looking at... everything appears to be the same but the part numbers don't match... info would be greatly appreciated. Thank you. David
btw, does anyone know where I could find engineering schematics bike and bike parts? That would be my way of crossreferencing... if the dimensions fit they should work...
LinkBack URL
About LinkBacks
A2rider
