Old 03-25-2008   #1 (permalink)
BrianT
Cruising In Fourth Gear
BrianT's Avatar
Thumbs up Front Master Cylinder View Glass Replacement
Does anyone know where to get the Replacement View Glass for the front Master Cyliner for a 79 St Shaft which fits a ton of other Kawasaki's. I have my Parts catalog but it does not show just the View Window just shows the P/N for the master cylinder. Thanks
BrianT is offline   Reply With Quote
Old 03-25-2008   #2 (permalink)
Andy the gringo
KZ Addicted (needs Help)
Andy the gringo's Avatar
I don't believe Kawasaki sells just the sight glass by itself. I have a master cylinder from a 650 CSR that I managed to break while cleaning it out. I'm 99% sure I will be able to use the oil level sight glass from the clutch cover to repair this but as of yet I haven't gotten around to fixing it.
80 Z-1 Classic
84 GPZ1100
77&79 1000 LTD
76 KZ900
KZ750 X 2
KZ650 X 7
KZ550 X3
305 CSR
Andy the gringo is online now   Reply With Quote
Old 03-25-2008   #3 (permalink)
Solera
Finally Got Into First Gear
The glass is NOT,, sold separately.
Solera is offline   Reply With Quote
Old 07-31-2008   #4 (permalink)
Fredvs79
Wrench turner
Fredvs79's Avatar
bringing back a post from the past - this obviously should be a replaceable part! Can anyone say AFTERMARKET!
Fredvs79 is offline   Reply With Quote
Old 07-31-2008   #5 (permalink)
antiq
Vintage bike addict
antiq's Avatar
Someone else posted they replaced it with a dime and some epoxy. You can probably do the same or use a dime size piece of plexiglass. If you want to take the time to fab up the tools you could cut a replacement from glass.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince
antiq is offline   Reply With Quote
Old 07-31-2008   #6 (permalink)
StarGate
StarGate's Avatar
I've got a diamond wet grinder I use for my stained glass projects. No need to fab tools.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 07-31-2008   #7 (permalink)
antiq
Vintage bike addict
antiq's Avatar
Or you could use a drill press with the proper size tubing and cutting compound. Have you tried using that wet grinder for polishing stone? It will do a nice job. I used to make jewelry.
Old 07-31-2008   #8 (permalink)
A2rider
Banned
Oh, thanks, Mike. Visions of stained glass side covers just came to mind. It would look so cool with the paint job I have.
A2rider is offline   Reply With Quote
Old 07-31-2008   #9 (permalink)
StarGate
StarGate's Avatar
Haven't tried it on any stone. Seems a bit coarse for that application. I've always been interested in those polished stones and how they look when finished.
Well I've made everything from mini tiffany lamp style night lights up to an 8' wide 2.5' tall arch top window insert. I guess side covers would just add to the assortment. Haven't done any of it in a few years and don't have my cutting table set up since my last move.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
Old 07-31-2008   #10 (permalink)
Fredvs79
Wrench turner
Fredvs79's Avatar
Well you need to get right on this man!!! CHOP CHOP!
Old 08-01-2008   #11 (permalink)
A2rider
Banned
Wonder if I could still use the plastic frames to hold the stained glass in place?
Old 08-01-2008   #12 (permalink)
herk
bustedfeet
herk's Avatar
delete
herk is offline   Reply With Quote
Old 08-01-2008   #13 (permalink)
Fredvs79
Wrench turner
Fredvs79's Avatar
Originally Posted by herk View Post
My bike is the 81 KZ650-CSR.
The mc site glass appears to be the same size as the oil level gauge...
The oil level gauge is listed as Active at Kawasaki.com - RonAyers.com shows a price of $8.48 (Kaw part #52005-1009).
Z1Enterprises.com lists an oem oil level gauge for $13.75 - 52015-004. JMK.
When you say oil level gauge, I take it you mean the sight glass? Well, you must have a different bike, on mine the oil sight glass is probably as big as a quarter, while the MC sight glass on the brake and clutch can't be any bigger than a dime.
Old 08-01-2008   #14 (permalink)
antiq
Vintage bike addict
antiq's Avatar
How would you incorporate the chain mesh to stained glass? It would be nice with lighting behind it though.
Old 08-02-2008   #15 (permalink)
Fredvs79
Wrench turner
Fredvs79's Avatar
Though the feasibility seems nigh impossible, even I have to concede that backlit sight glasses in tinted colors like red, orange or green would be real trick. Where do I sign up for em?
Old 08-02-2008   #16 (permalink)
Fredvs79
Wrench turner
Fredvs79's Avatar
I took some photos today of my MC on the brake side - the clutch side was nearly identical. Hold your comments on the gunk on the walls, I see it too. The level is low because I drained it a little so you could see the back of the sight glass better. There seems to be a metal bracket in the way of directly swabbing the plastic lens, so I'm at a loss for how to clean it.
http://farm4.static.flickr.com/3080/...a3257e.jpg?v=0
http://farm4.static.flickr.com/3282/...7b9a30.jpg?v=0
front-master-cylinder-view-glass-replacement-gpz1.jpg  front-master-cylinder-view-glass-replacement-gpz2.jpg
Old 08-02-2008   #17 (permalink)
herk
bustedfeet
herk's Avatar
delete
Ninja Front Turn Signal Replacement SFAcoustic The Mechanics Corner 1 04-09-2006 03:54 PM
Front Turn Signals Replacement - Input SleekStreak Kawasaki Cruisers 9 03-17-2006 11:24 AM
Front master cylinder (KZ1000) question... kartek Vintage Motorcyle Info 3 01-15-2006 11:41 PM
replacement front brake lever for 500r? chiatello Kawasaki Streetbikes/Sportbikes 6 08-14-2005 12:08 PM
Front Fender Replacement - Help jroskelley Kawasaki Cruisers 5 03-25-2005 07:34 AM
