Old 04-17-2008   #21 (permalink)
NCDave
Novice Tank Roller
NCDave's Avatar
...and I'm having problems with my new motorcycle. Can anyone help? I think it's the right color, but beyond that, I'm not sure.
NCDave
Loud pipes save deer!
http://www.bikepics.com/members/ncdave/
NCDave is offline   Reply With Quote
Old 04-18-2008   #22 (permalink)
A2rider
Banned
Originally Posted by Nate View Post
My bike won't ride. What is wrong? HELP ME!!!!
I'll fix it in June when we break bread and go for a ride. Or I can spray paint it blue and sell you some Yamaha parts!
A2rider is offline   Reply With Quote
Old 04-20-2008   #23 (permalink)
antiq
Vintage bike addict
antiq's Avatar
Put the rubber down Dave.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince
antiq is offline   Reply With Quote
Old 07-04-2008   #24 (permalink)
RAGG_MOP
RAGG_MOP's Avatar
well i wanted a white and silver 900 but i got a red and black .. go figur
RAGG_MOP is offline   Reply With Quote
Old 07-04-2008   #25 (permalink)
RAGG_MOP
RAGG_MOP's Avatar
Default chopper ?
and one have a 1972 harley chopper
Old 07-04-2008   #26 (permalink)
RAGG_MOP
RAGG_MOP's Avatar
dave ? are u on line
now
Old 07-07-2008   #27 (permalink)
Mobilemover
Thanks for the info on how to post correct info......
I just recently bought a 1990 Kawasaki 454ltd.
It has been in storage for 5yrs, with the gas tank drained, carbs drained, and covered with a tarp in a storage bldg, up on center stand. The bike is nearly in a like new condition all over, it has only been driven for 5950miles. The original owner developed arthritis in both knees and just parked it in storage.
I bought a manual and went through the step by step process of carefully removing both carbs, and disassimbling them and cleaning them throughly.
both carbs were very clean inside, so I only removed the basic essentials to clean out the ports and where any gum or varnish would hide. I've replaced the battery with a new one, added fresh gas, checked the oil level, closed the bottom drain holes on both carbs, and cranked over a couple times. It will start with the choke full on, but will not stay running; also if I try to give it some throttle, it bogs out or dies, if I ease up on the choke, it might start and run, but run rough, or else die again. I cant tell if I'm getting good enough spark at the plugs, but then, it will start right up so I figure that it must be getting spark at the plugs, I just know know if the ICC unit is allowing enough spark to the plugs, or it's something else. Like vacume. I noticed when the carbs were apart, there was a spring loaded diaphragm inside that seem to act as a "gate" in the opening of the throttle body, to allow for more air flow/vacume; so, my deduction for a bad idle is that there is not enough vacume getting to one of the carbs and pulling that spring loaded diaphram up high enough to allow for more air through the carbs and a better throttle response. does that sound right to you?
what else could do to make this run smooth. I have no reason to think that any settings have been "toyed" with since it was covered with a complete tarp, in a locked bldg, so I have'nt tried to monkey with any of the idle adjustment screws or anything else.
also one last thing, do you know about what goes between the upright bars behind the front seat, just above the tail light? mine is missing.
thank you for any help you can advise.....
mobilemover
Mobilemover is offline   Reply With Quote
Old 07-08-2008   #28 (permalink)
StarGate
StarGate's Avatar
Now all you need to do is copy and paste this into a new thread. Not many people are going to look in here unless they are reading the OP like you did.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 12-20-2008   #29 (permalink)
kelly_canales20
hey man im a newbie i have a 1982 kawasaki kz 440 ltd belt drive with a little over six thousand miles on it. It is a daily driver and i fix it up a little when i have time i think the carbs need to be rejetted and the rubber housing that connects the carbs to the aircleaner box are cracked (no idea how to replace) but main and first concern is a missing air box that covers the air filter. this thing is discontinued and practically non existant any knowledge on where to find or how to fabricate would be greatly appreciated. Or any sense of direction for that matter thank you.
kelly_canales20 is offline   Reply With Quote
Old 12-22-2008   #30 (permalink)
RAGG_MOP
RAGG_MOP's Avatar
anyone Needing Parts For A 1982 Kawasaki 440 Kz Should Go To
Motorcycle Superstore [ 1-877_668-6872
[/b]
Old 12-22-2008   #31 (permalink)
RAGG_MOP
RAGG_MOP's Avatar
motorcycle Superstore Phone
1-877-668-6872
Just got my bike, then it got stolen (videos of theft) NovaPhoenix Main Lobby 138 06-29-2008 01:13 AM
Bike problems... need help wolnt fire...... ninjaguy1288 Kawasaki Streetbikes/Sportbikes 10 10-08-2007 02:53 PM
I can fix my own bike GreenJello What I learned today 9 11-15-2006 01:59 PM
bike is in the shop, with more problems 99ZX7R The Mechanics Corner 4 10-25-2006 06:07 PM
problems to turn on my bike... Gengis Khan The Mechanics Corner 3 07-28-2005 03:58 PM
