no more newbie
I bought a 1986 Kawasaki zl 600 Eliminator, and currently putting it back together. I got the carbs cleaned and put back together, but i can't figure out the vaccum hoses. The repair manuel isn't much help, please help this is driving me crazy.
Vintage bike addict
If it's set up like mine. The outside cab vacuum ports are connected to the vacuum assembly up under the tank. The port on the second carb in on the left is attached to the fuel petcock. I hope that helps. Mine is an 82 750ltd.
Patience and persistance- pays 82 KZ750LTD 78 KZ750 twin Vince |
#7 (permalink) |
Navy Vet S.A.R. crew
Look at the carbs as you open the throttle. It should be lifting (pulling up) as it goes from idle position toward full throttle. Don't think it can be installed backwards. I suspect you have an air leak around your carb holders. Check to make sure all the vacuum hoses are good/no cracks and that all unused ports are capped off. Use some spray carb cleaner and spray around the boots from all angles while it's idling and listen for an rpm change when you hit the leaky spot.
#14 (permalink) |
Sounds like it's either not getting enough fuel from the petcock (try a secondary fuel tank such as a 20 oz. bottle with a nipple) or the vacuums are not getting along (connect 3 & 4 with a small piece of hose, 1 to the petcock & cap off 2)
To sync the carbs without a sync tool just get a few feet of clear tubing & some motor oil or tranny fluid to put in the tubing (just enough to see the ripples/waves).. Connect 1 & 2 using the tubing and adjust the butterfly screw until you get the fluid to stay in place. Do the same for 3 & 4 then finally sync the 2 sides. Might want to make a spare fuel tank from a bottle to make the process much easier Last edited by Trip107 : 07-22-2008 at 11:26 AM. |
| Pod Filters on 600R - How to re-route vacuum lines? | c00lkatz | Kawasaki Streetbikes/Sportbikes | 2 | 04-17-2006 10:54 PM |
| Fuel & Vacuum Lines | jonm61 | The Mechanics Corner | 2 | 01-30-2006 03:49 PM |
| Hoses and vacuum lines ??????? | motoxracer | The Mechanics Corner | 4 | 01-06-2006 05:28 PM |
| HELP Fuel and Vacuum Lines to Carb 85 ZX900/GPZ900 *pics* | megahyperion | Kawasaki Streetbikes/Sportbikes | 28 | 06-26-2004 02:18 AM |
| Carb vacuum hoses | Chiefpb | The Mechanics Corner | 4 | 06-25-2004 07:05 PM |
