Ok, so today I tried to change my fuel filter. I got one thats universal but that fits with no clearance issues. I also got all new 1/4" fuel line to go ahead and replace that.
Well I got everything off and put the new lines and filter in place. Cinched it all down good and tight, and low and behold I had a fuel leak. I found that the leak was coming from a screwed up clamp that pinched the line above the splitter at the carbs. Well I pulled it back off and changed the line from the filter to the carb and put on another clamp and made sure that everything was good and tight and nothing was pinched or kinked. Now, I still have a fuel leak.
It leaks when I turn the petcock on. But there dont seem to be much fuel in the filter. What could be causing this?
LinkBack URL
About LinkBacks
