Old 05-07-2008   #1 (permalink)
80KAW650
80KAW650
80KAW650's Avatar
Default 1980 KZ650 Coils
While rebuilding the carbs and replacing the valve cover gasket I discovered that both of my coils are cracked open, obviously not good. To buy the exact same coils and wires it's going to run me about $400, which I don't have. Now I noticed that Z1 has Dyna dual output coils for around $120 per pair. Now my questions; would it be a good purchase and how do I know what ohm my current coils are, Dyna offers 1.5, 2.2, and 3.0?
80KAW650 is offline   Reply With Quote
Old 05-07-2008   #2 (permalink)
StarGate
Navy Vet S.A.R. crew
StarGate's Avatar
Look in your service manual under the section that covers troubleshooting the ignition. There should be a check for the coils where it will give a resistance range. For mine, they should read 1.8-2.8 ohms. Then you get the coil that falls in the middle of that range or closest to it. I got the 2.2 ohm. And thats not the only 3 that Dyna makes.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Photos
Old 05-07-2008   #3 (permalink)
OKC_Kent
Can't find time to ride
OKC_Kent's Avatar
Don't quote me, check by calling Jeff at Z1. I think the 650's use 3 ohm. And Z1 also has a generic looking coil for $35 that should work. Again, call Jeff and tell him what you have.
Kent
Oklahoma City, OK
'78 KZ 650 B2
'83 KZ 750 LTD F1 Shaft
OKC_Kent is offline   Reply With Quote
Old 05-08-2008   #4 (permalink)
80KAW650
80KAW650
80KAW650's Avatar
Excellent, thanks.
Old 05-08-2008   #5 (permalink)
Nate
KZ Kool!
Nate's Avatar
I've installed the 3 ohm ACCEL kit which includes the wires on my 650 and it works well. I was able to buy it through Motorcycle Accessory Warehouse via eBay. The ACCEL coils also work well with the Dyna S ignition module and makes for a very smooth idling engine.
Just another choice to consider.
"Riding is the reward for time spent wrenching."
"Wrenching is the result of time spent riding!"
KZ650 SR
Nate is offline   Reply With Quote
dyna coils on 1980 KZ1000 Ace Cafe Vintage Motorcyle Info 1 01-14-2008 11:58 AM
Coils that'll work on a KZ650 D-Day Vintage Motorcyle Info 20 05-09-2007 10:48 PM
1980 KZ650 Head Interchangeable with 1978? 1978KZ650B Vintage Motorcyle Info 8 05-05-2007 02:19 AM
1980 KZ650 For Sale Columbia, MO DanAmp Streetbikes Buy/Sell/Trade 0 03-21-2005 04:58 PM
newbie 1980 kz650 n9915t Vintage Motorcyle Info 3 09-29-2004 02:54 PM
