Old 06-10-2008   #1 (permalink)
Gross
Crash&Burn
Gross's Avatar
Default Electronic Ignition for '77 KZ1000-LTD
Has anybody out there put in one of the Dyna 2000 ingnitions? If so, how did it work out? Any install problems? Was the performance better? Was it worth it?
How about other types of electronic ignitions? Let me know what and how it worked out.
Thanks.
Ride smart, ride safe.
1977 KZ1000-LTD
Gross is offline   Reply With Quote
Old 06-10-2008   #2 (permalink)
StarGate
StarGate's Avatar
Haven't installed one but my understanding is that the 2000 is more of a drag/racing bike unit for variable timing curves and the Dyna S is for upgrading points ignition to electronic and much cheaper than the 2000.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 07-10-2008   #3 (permalink)
KZ1100S
I would also like to know where we buy these electronic ignitions?
Can someone give me the name of 2r3.
Thanks
KZ1100S is offline   Reply With Quote
Old 07-10-2008   #4 (permalink)
Jeff.saunders
Obsessed by Z1's
Jeff.saunders's Avatar
Send a message via AIM to Jeff.saunders
The Dyna-S is an economical replacement for points. Simple to install and reliable. The down side is it still uses the factory mechanical advancer.
The Dyna 2000 is much more sophisticated. The ignition advance is all electronic - so say goodbye to the mechanical advancer. In the 'out the box' form, you have a handful of selectable advance / retard curves. With the optional software programming kit, you can tailor your ignition settings using a PC. You get an adjustable built-in rev-limiter, security cut-out and feeds for an electronic tach.
On most stock or near stock street bikes, the Dyna-S is all you need. Once you step up and start adding higher performance components in the engine, the Dyna 2000 is the way to go.
I run a Dyna 2000 on my 1200cc turbo'd Z1 - the retard curve settings are really essential for a turbo setup.
jeff@z1enterprises.com 1973 turbo'd Z1, 1973 stock Z1
www.z1enterprises.com
Jeff.saunders is offline   Reply With Quote
Old 07-11-2008   #5 (permalink)
Nessism
Turtle Wax Taster
Take note of the Z1enterprises link in Jeff's post. They sell the Dyna S for a reasonable price and have quick shipping. Good vendor.
Nessism is offline   Reply With Quote
Fan switch question rd3500 The Mechanics Corner 3 10-15-2007 03:31 PM
My first bike 85 ninja gpz900R Blkmaroman Vintage Motorcyle Info 28 10-08-2007 11:36 PM
KZ1000 ignition - need help markdavjones Vintage Motorcyle Info 5 08-07-2007 09:10 PM
Dyna Ignition For KZ1000 CRAZYTasty Kawasaki Streetbikes/Sportbikes 2 07-03-2007 01:26 PM
Electronic ignition dbdb Vintage Motorcyle Info 6 09-21-2005 07:04 AM
