Old 06-19-2008   #1 (permalink)
stevec6535
Default 1981 Kawasaki 750 LTD Starter Problem
Hi. Im hoping that somebody out there can give me some advice. I got a 1981 Kawasaki 750 LTD 4 Cyl. form a guy how was going over to Iraq, so he did not want it any more. It was given to him and he never rode it. He was told that it ran but the starter was "BlownUp". When I got it home I noticed that there were a number of issues with melted wires, spliced wires ect. I hooked a 12v battery directly to the starter to see if it would even turn over and the starter just spun. I pulled the starter off of the bike and bench tested it and it appears to be working just fine,no stripped gears inside and the spur gear looks good also but when I put it back on the bike the starter dosen't seem to be engaging with the fly wheel. when I stick my finger inside the starter hole the fly wheel will spin freely in one direction and it locks up in the other. I am guessing that the fly wheel is mounted on a 1 way bearing. Has anybody ever seen od dealt with this before? Any suggestions will be greatly appreciated.
stevec6535 is offline   Reply With Quote
Old 06-19-2008   #2 (permalink)
JG6_oddball
Clutch Cadet
JG6_oddball's Avatar
when u bench tested it did it spin? or kick out and spin?
81,CB750K
78,GS550
8?,CX500
83,KZ750
81,KZ440
81,XV920
86,ZG1000
82 XJ1100 Maxim (current)
JG6_oddball is offline   Reply With Quote
Old 06-20-2008   #3 (permalink)
stevec6535
It just spun but it did not kick out
Old 06-20-2008   #4 (permalink)
stevec6535
There is not a external starter solinoid on this starter. Is there one on the inside?
Old 06-20-2008   #5 (permalink)
Andy the gringo
KZ Addicted (needs Help)
Andy the gringo's Avatar
The solenoid for the bike is located under the left side cover. Follow the positive lead from the battery and you will find it.
80 Z-1 Classic
84 GPZ1100
77&79 1000 LTD
76 KZ900
KZ750 X 2
KZ650 X 7
KZ550 X3
305 CSR
Andy the gringo is offline   Reply With Quote
Old 06-20-2008   #6 (permalink)
JG6_oddball
Clutch Cadet
LFU has a good explanation of what is most likely happening to your bike
Originally Posted by LoudFastUgly View Post
CLUTCH: a mechanism for readily engaging or disengaging a shaft that drives a mechanism or is driven by another part.
Modern auto starter motors are equipped with a "bendix," a gear and integral freewheel, or overrunning clutch, thereby allowing the flywheel to automatically disengage the pinion gear from the flywheel when the engine starts.
Kawasaki KZ550, GPz550 and ZX550 have a seperate starter motor and clutch assemblies. They are not one complete unit as an automotove starter.
It is well known that the CLUTCH in this starter SYSTEM fails, the starter motor will turn, but the engine does not crank. The GEARS mesh constantly (unlike an automotive starter), the CLUTCH seperates the starter motor from the crankshaft via the secondary shaft and the primary chain after startup.
S!
81,CB750K
78,GS550
8?,CX500
83,KZ750
81,KZ440
81,XV920
86,ZG1000
Old 06-21-2008   #7 (permalink)
antiq
Vintage bike addict
antiq's Avatar
Sounds like the starter clutch has gone bad. It's inside the lower engine case.
82 KZ750LTD, 84 Virago 700, 85 Vulcan 700.78 KZ750 twin,82 KZ650, 77 KZ650, 75 CB200T,Vince
antiq is offline   Reply With Quote
EX500 Electrical / Starter Problem shipbldr2000 The Mechanics Corner 10 05-21-2009 08:30 PM
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
Zx-6r 1995 starter problem FinKawa The Mechanics Corner 4 10-22-2007 01:50 AM
1981 Kawasaki 750 ltd baffels twilli Vintage Motorcyle Info 0 06-12-2006 10:53 AM
Yamaha & Kawasaki Billet Starter & Horn Buttons Cycle-Parts Accessory Swap Meet 0 04-25-2004 12:38 AM
