Old 07-05-2008   #1 (permalink)
ratvespa
Turtle Wax Taster
ratvespa's Avatar
Default 80's EFI technolagy!
ok, I was a loafing around reading my kawi repair manual for my soon to be running 82 GPz1100 with efi (now with 100% more wiesco big bore goodness!).
So anyway, I was checking out the wiring diagram for the EFI, noticed that the all 4 of the injectors had one common power, and one common ground. Unlike most all EFI I have delt with, one common ground, then each injector has it's own power wire, so they can open up individually. So, question is, do all the injectors fire at the same time? I cannon imagine that being to efficient. Did any cars do this or was this a 80's bike thing?
If thats the case, I wonder how much more power and efficiency I could get out of going megasquirt (or microsquirt). I think I'll get it running with the factory set up, mabey do the break in on the pistons, then start tinkering with the 'squirt.
ratvespa is offline   Reply With Quote
Old 07-06-2008   #2 (permalink)
KZQuixote
Broke Neck Hoople
Hi RatVespa,
Yes they all squirt at the same time. These systems are not referred to as EFI but rather DFI.
I only have one injected bike but have worked through it pretty thoroughly. It's a 1985 ZN1300.
There are two methods of adjusting the mixture. Fine adjustments can be done by tweaking the throttle position sensor very slightly. Larger adjustments require an adjustable fuel pressure regulator.
I have no experience with the aftermarket systems you mentioned.
Regards
KZQuixote
Lifelong rider suffering through MBD.
KZQuixote is offline   Reply With Quote
Old 07-06-2008   #3 (permalink)
PatsPOS
PatsPOS's Avatar
Send a message via AIM to PatsPOS Send a message via Yahoo to PatsPOS
Well, rat...I dunno if all auto manufacturers did it, but in the earlier part of Ford's EEC-IV days, they had what was called "batch-fire", where four of the eight injectors (or three of the six on a 6-cylinder, or all four on a 4-cylinder) would get power simultaneously, then the other four. That sounds the most similar to what you have. Later on, Ford had a better idea and developed their own version of sequential fuel injection, where each injector sprayed independently.
I believe the Fords with SFI did better economically than the ones with batch-fire...but the difference was negligible. However (and with no scientific explanation!), my gut tells me that some kind of sequential injection on a bike engine would deliver significantly better economy than the batch-fire. Just my 2¢.
Pat
'82 CSR 650
PatsPOS is offline   Reply With Quote
How to identify early 80's KX80? draaino Kawasaki Motocross and Offroad 8 06-12-2008 06:53 AM
2005 1500 efi CurraheeDuck Kawasaki Cruisers 3 04-16-2007 05:33 AM
picking up a 80's zx600 dange Kawasaki Streetbikes/Sportbikes 22 10-30-2006 03:31 PM
