Old 07-14-2008   #1 (permalink)
girlnamedgo
Send a message via AIM to girlnamedgo
Default 1978 kz200
Hi, I just bought a 1978 kz200. It's in pretty perfect condition, it's only got 1700 miles on it. It runs fine, for a while. Yesterday I went for a ride after work, but maybe 20-30 minutes into the ride, the rpms just dropped. I could kick start it, but it wouldn't keep running. The push start wouldn't work. After about 15 minutes I could push start it again, and it would keep running. About that time, my boyfriend showed up with his truck to load it up. I turned it off, but wanted to see one more time if I could push start it again.. and it wouldn't start up. Started up just fine again this morning.
What could be wrong with it? Clogged fuel filter? Bad gas? Something with the heating/cooling?
Thanks for any help!
girlnamedgo is offline   Reply With Quote
Old 07-14-2008   #2 (permalink)
LoudFastUgly
Got KZ?
LoudFastUgly's Avatar
ckeck fuel filter and lines first.
KZ550A4
LoudFastUgly is offline   Reply With Quote
Old 07-15-2008   #3 (permalink)
bobbyjim
Banned
I have a factory original Kawasaki KZ200 Service Manual for sale. If needed let me know.
bobbyjim is offline   Reply With Quote
Old 07-16-2008   #4 (permalink)
slow bike
I just got a KZ200 and got it running good, but I could use a little more top end speed. Can I replace my 17 inch wheel with a 18 inch wheel from A KZ400. I need to know if this will work, and if not what do you recomend.
slow bike is offline   Reply With Quote
Old 07-16-2008   #5 (permalink)
Vulcan900
Vee-Too-Kay
Vulcan900's Avatar
This could be a tank vent issue. As gas leaves the tank air is pulled in the vent. If the vent is clogged no air can get into the tank, and eventually no gas can get out due to the vacuum created.
Try opening the gas cap when symptoms begin to appear, if this solves the problem then a removal and cleaning of the tank vent is in order.
2006 VN2000 LT - Fire Breathing Dragon
2006 VN900 Classic - Mellow Kitten
Vulcan900 is online now   Reply With Quote
Old 07-16-2008   #6 (permalink)
girlnamedgo
there's a screw missing from the carb. i'm guessing this is the problem.. the screw missing is where the carb goes into the engine, so the hole is in the engine. other than that, i need a new battery.
Old 07-16-2008   #7 (permalink)
StarGate
StarGate's Avatar
You need to start a new thread with your problem instead of posting it in a current and ongoing thread. It would be more practical to change the gear ratio with a sprocket change than a wheel/tire change.
Mike
Original Owner
1981 KZ1000-K1 LTD
2000 Suzuki King Quad
Refurbish Photos
Old 07-17-2008   #8 (permalink)
slow bike
Sorry about that, this is the first time I have used a forum. I am also having trouble finding a back tire that is the right size, I thought I could get two birds with one stone. Could you recomend a place to get a 3.25-17 4PR If you could that would solve my problem, and I could just change the sprocket, much easier.
Old 07-17-2008   #9 (permalink)
StarGate
StarGate's Avatar
Check the sticky thread at the top of this section for a list of suppliers.
Mike
Original Owner
1981 KZ1000-K1 LTD
Refurbish Photos
1978 Kz 1000 earlfo Vintage Motorcyle Info 12 08-03-2008 07:51 AM
1978 KZ200 vs KZ200A jstoezel Vintage Motorcyle Info 4 03-25-2008 09:42 AM
Float Level Specs - 1978 KZ200 CTRider Vintage Motorcyle Info 7 05-10-2007 04:15 PM
Float level specs for a 1978 KZ200? CTRider The Mechanics Corner 0 09-14-2006 05:05 AM
